주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BLU Vivo 5 Mini Camera Replacement
필요한 것
  1. BLU Vivo 5 Mini Camera Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 BLU Vivo 5 Mini Camera Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 BLU Vivo 5 Mini Camera Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the 2 screws along the bottom on either side of the speaker port with the size 2 Pentalobe driver.
    • After screws are removed, dislodge the speaker and charger port cover from device using the tweezers.
  2. BLU Vivo 5 Mini Camera Replacement: 2 단계, 이미지 3개 중 1개 BLU Vivo 5 Mini Camera Replacement: 2 단계, 이미지 3개 중 2개 BLU Vivo 5 Mini Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the top and bottom covers.
    • Start by sliding the pick around the edges of both covers. (If you have the glue adhesive removal tool use that instead of pick, as it creates less damage.)
    • After freeing the edges gentle start peeling the covers off.
  3. BLU Vivo 5 Mini Camera Replacement: 3 단계, 이미지 3개 중 1개 BLU Vivo 5 Mini Camera Replacement: 3 단계, 이미지 3개 중 2개 BLU Vivo 5 Mini Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Using a Phillips #000, remove all 10 screws found on the back of the phone.
    • The 6 on the bottom are to be removed with a size PH000 Phillips Head screwdriver.
    • The 4 on the top can be removed with the same screwdriver.
  4. BLU Vivo 5 Mini Camera Replacement: 4 단계, 이미지 3개 중 1개 BLU Vivo 5 Mini Camera Replacement: 4 단계, 이미지 3개 중 2개 BLU Vivo 5 Mini Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Completely remove SIM card port from side of phone using the SIM Card Eject Tool.
    • Release the back cover (it may be glued down encasing the phone) using the suction device to lift the back off.
    • Begin inserting the pick sliding it between the back of the phone and the cover to completely remove back cover, if suction does not lift.
  5. BLU Vivo 5 Mini Camera Replacement, Camera: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, remove the top black encasing of the camera.
  6. BLU Vivo 5 Mini Camera Replacement: 6 단계, 이미지 3개 중 1개 BLU Vivo 5 Mini Camera Replacement: 6 단계, 이미지 3개 중 2개 BLU Vivo 5 Mini Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Using the tweezers unlink the camera gently from the gold wire
  7. BLU Vivo 5 Mini Camera Replacement: 7 단계, 이미지 2개 중 1개 BLU Vivo 5 Mini Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Gently lift the back camera from the phone.
    • Be careful not to smudge the lens. At this time, also check for debris.
  8. BLU Vivo 5 Mini Camera Replacement: 8 단계, 이미지 3개 중 1개 BLU Vivo 5 Mini Camera Replacement: 8 단계, 이미지 3개 중 2개 BLU Vivo 5 Mini Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Use the spudger to gently lift the motherboard out of the device.
    • After completely removing the back camera and motherboard, now check underneath for debris near front lens.
    • Front lens can now be removed for replacement.
결론
작성자
5다른 기여자 명과 함께
Kymari
회원 가입일: 10/09/18
725 평판
안내서 5개를 작성함
Sam Houston State, Team S15-G6, Blackburne Fall 2018 Sam Houston State, Team S15-G6, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G6
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 22
전체 시간: 415
