주요 콘텐츠로 건너뛰기
BLU Vivo 5 Mini Speaker Replacement
필요한 것
  1. BLU Vivo 5 Mini Speaker Replacement, Back Cover: 1 단계, 이미지 1/3 BLU Vivo 5 Mini Speaker Replacement, Back Cover: 1 단계, 이미지 2/3 BLU Vivo 5 Mini Speaker Replacement, Back Cover: 1 단계, 이미지 3/3
    • Remove the 2 screws along the bottom on either side of the speaker port with the size 2 Pentalobe driver.
    • After screws are removed, dislodge the speaker and charger port cover from device using the tweezers.
  2. BLU Vivo 5 Mini Speaker Replacement: 2 단계, 이미지 1/3 BLU Vivo 5 Mini Speaker Replacement: 2 단계, 이미지 2/3 BLU Vivo 5 Mini Speaker Replacement: 2 단계, 이미지 3/3
    • Remove the top and bottom covers.
    • Start by sliding the pick around the edges of both covers. (If you have the glue adhesive removal tool use that instead of pick, as it creates less damage.)
    • After freeing the edges gentle start peeling the covers off.
  3. BLU Vivo 5 Mini Speaker Replacement: 3 단계, 이미지 1/3 BLU Vivo 5 Mini Speaker Replacement: 3 단계, 이미지 2/3 BLU Vivo 5 Mini Speaker Replacement: 3 단계, 이미지 3/3
    • Using a Phillips #000, remove all 10 screws found on the back of the phone.
    • The 6 on the bottom are to be removed with a size PH000 Phillips Head screwdriver.
    • The 4 on the top can be removed with the same screwdriver.
  4. BLU Vivo 5 Mini Speaker Replacement: 4 단계, 이미지 1/3 BLU Vivo 5 Mini Speaker Replacement: 4 단계, 이미지 2/3 BLU Vivo 5 Mini Speaker Replacement: 4 단계, 이미지 3/3
    • Completely remove SIM card port from side of phone using the SIM Card Eject Tool.
    • Release the back cover (it may be glued down encasing the phone) using the suction device to lift the back off.
    • Begin inserting the pick sliding it between the back of the phone and the cover to completely remove back cover, if suction does not lift.
  5. BLU Vivo 5 Mini Speaker Replacement, Speaker: 5 단계, 이미지 1/2 BLU Vivo 5 Mini Speaker Replacement, Speaker: 5 단계, 이미지 2/2
    • Slide the spudger between the speaker covers (might be held down with adhesive stickiness.)
    • Use the PH000 screwdriver to remove any leftover screws near bottom of the device.
  6. BLU Vivo 5 Mini Speaker Replacement: 6 단계, 이미지 1/1
    • Gently slide the pick between the black sound motherboard (located under the battery.)
    • Use the tweezers to lift speaker motherboard out of device.
  7. BLU Vivo 5 Mini Speaker Replacement: 7 단계, 이미지 1/1
    • After checking for debris and water surrounding the speaker area, replace with new speaker.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kymari
회원 가입일: 10/09/18
710 평판
안내서 5개 작성하였습니다
Sam Houston State, Team S15-G6, Blackburne Fall 2018 Sam Houston State, Team S15-G6, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 200
