주요 콘텐츠로 건너뛰기
BLU WIN HD LTE Camera Replacement
필요한 것
  1. BLU WIN HD LTE Camera Replacement, Back Case: 1 단계, 이미지 1/1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Camera Replacement: 2 단계, 이미지 1/1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Camera Replacement, Frame Cover: 3 단계, 이미지 1/1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Camera Replacement: 4 단계, 이미지 1/1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Camera Replacement, Camera: 5 단계, 이미지 1/3 BLU WIN HD LTE Camera Replacement, Camera: 5 단계, 이미지 2/3 BLU WIN HD LTE Camera Replacement, Camera: 5 단계, 이미지 3/3
    • Pry off the low profile connector located on the right side of the camera device.
  6. BLU WIN HD LTE Camera Replacement: 6 단계, 이미지 1/1
    • Pull the camera out.
결론
Taelar Tritton-Bowman
회원 가입일: 09/21/18
249 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 5
전체 시간: 285
