주요 콘텐츠로 건너뛰기
BLU WIN HD LTE Frame Cover Replacement
필요한 것
  1. BLU WIN HD LTE Frame Cover Replacement, Back Case: 1 단계, 이미지 1/1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Frame Cover Replacement: 2 단계, 이미지 1/1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Frame Cover Replacement, Frame Cover: 3 단계, 이미지 1/1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Frame Cover Replacement: 4 단계, 이미지 1/1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
결론
To reassemble your device, follow these instructions in reverse order. Ensure that all sides of the frame cover are firmly snapped on before replacing the screws.
다른 한 분이 해당 안내서를 완성하였습니다.
Tione Gooden
회원 가입일: 09/21/18
269 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 173
