주요 콘텐츠로 건너뛰기
BMW 2003-2010 5 Series Tail Light Bulb Replacement
필요한 것
  1. BMW 2003-2010 5 Series Tail Light Bulb Replacement, Tail light Bulb: 1 단계, 이미지 1/1
    • Open the trunk of the car to access the tail lights.
    • Remove the two 5 mm screws holding the panel cover in place.
  2. BMW 2003-2010 5 Series Tail Light Bulb Replacement: 2 단계, 이미지 1/1
    • With a flathead screwdriver, turn the screws half a turn counterclockwise.
  3. BMW 2003-2010 5 Series Tail Light Bulb Replacement: 3 단계, 이미지 1/1
    • With plyers, remove the screws.
  4. BMW 2003-2010 5 Series Tail Light Bulb Replacement: 4 단계, 이미지 1/3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: 4 단계, 이미지 2/3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: 4 단계, 이미지 3/3
    • Pull up the trunk matt and remove it from the corner.
    • Pull up the panel by the tab.
    • The panel should lift right out.
  5. BMW 2003-2010 5 Series Tail Light Bulb Replacement: 5 단계, 이미지 1/3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: 5 단계, 이미지 2/3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: 5 단계, 이미지 3/3
    • You will see the light bulb holster.
    • Turn the dial in the middle of of the black plastic light bulb holster.
    • Pull the holster out of the trunk bay.
  6. BMW 2003-2010 5 Series Tail Light Bulb Replacement: 6 단계, 이미지 1/1
    • Grab the light bulb at the base and twist counterclockwise.
    • DO NOT TWIST THE BULB BY THE GLASS.
  7. BMW 2003-2010 5 Series Tail Light Bulb Replacement: 7 단계, 이미지 1/1
    • Pull out the bulb and repeat the process in reverse order with the new bulb to reassemble.
결론
To reassemble, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Christophe Chedid
회원 가입일: 03/22/21
169 평판
안내서 1개 작성함
UMass Dartmouth, Team S3-G5, Saloman Spring 2021 UMass Dartmouth, Team S3-G5, Saloman Spring 2021 회원
UMASSD-SALOMAN-S21S3G5
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 65
전체 시간: 2,775
