소개
This guide will help you replace a burnt out tail light on your 2003-2010 BMW 5 Series car. Neglecting regular car maintenance such as changing a tail light can cause many problems including a ticket or worst.
This is a quick and easy job that any one can do and you’ll save money too. Follow this step-by-step guide to change the tail light on your 2003-2010 BMW 5 Series.
필요한 것
Open the trunk of the car to access the tail lights.
Remove the two 5 mm screws holding the panel cover in place.
To reassemble, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
