주요 콘텐츠로 건너뛰기
BMW 325i e90 Inner Tail Light Bulb Replacement
필요한 것
  1. BMW 325i e90 Inner Tail Light Bulb Replacement, Inner Tail Light Bulb: 1 단계, 이미지 1/2 BMW 325i e90 Inner Tail Light Bulb Replacement, Inner Tail Light Bulb: 1 단계, 이미지 2/2
    • Start by opening the trunk and locating the 8 plastic studs holding the trunk trim panel in place.
    • To remove the studs, dig a trim removal tool under them and use leverage to pop them out.
  2. BMW 325i e90 Inner Tail Light Bulb Replacement: 2 단계, 이미지 1/2 BMW 325i e90 Inner Tail Light Bulb Replacement: 2 단계, 이미지 2/2
    • Once the trim panel comes loose, it'll still be fastened to the trunck by a wire.
    • Make sure to leave the trim panel hanging since it'll expose the taillight housing enough to work on it in the next step.
  3. BMW 325i e90 Inner Tail Light Bulb Replacement: 3 단계, 이미지 1/2 BMW 325i e90 Inner Tail Light Bulb Replacement: 3 단계, 이미지 2/2
    • With the tail light bulb socket exposed, you'll need to first disconnect the wiring and then squeeze the plastic clip to release the entire bulb socket.
  4. BMW 325i e90 Inner Tail Light Bulb Replacement: 4 단계, 이미지 1/2 BMW 325i e90 Inner Tail Light Bulb Replacement: 4 단계, 이미지 2/2
    • Once you remove the bulb socket simply remove the faulty bulb by twisting and pulling, then replace it with a new one. Place the socket back in and listen for it to click.
결론
Once the new bulb is installed and the bulb housing is back in place, reconnect the wiring. Now simply line up the trunk trim panel and insert the studs in their corresponding holes to finish your bulb replacement.
Christopher Garcia
회원 가입일: 03/20/24
109 평판
안내서 1개 작성함
CSU Los Angeles, Team 1-75, Harris Spring 2024 CSU Los Angeles, Team 1-75, Harris Spring 2024 회원
CSULA-HARRIS-S24S1G75
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 65
전체 시간: 143
