주요 콘텐츠로 건너뛰기
BOSE SoundTouch 30 Motherboard Replacement
필요한 것
  1. BOSE SoundTouch 30 Motherboard Replacement, Base Plate: 1 단계, 이미지 1/2 BOSE SoundTouch 30 Motherboard Replacement, Base Plate: 1 단계, 이미지 2/2
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
  2. BOSE SoundTouch 30 Motherboard Replacement, Power Supply: 2 단계, 이미지 1/1
    • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
  3. BOSE SoundTouch 30 Motherboard Replacement: 3 단계, 이미지 1/2 BOSE SoundTouch 30 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
  4. BOSE SoundTouch 30 Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove all four 15.5 mm PH2 screws holding the power supply down.
    • The power supply is identified by a green board with a large metal covering.
  5. BOSE SoundTouch 30 Motherboard Replacement: 5 단계, 이미지 1/2 BOSE SoundTouch 30 Motherboard Replacement: 5 단계, 이미지 2/2
    • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
    • Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Remove the power supply.
  6. BOSE SoundTouch 30 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/3 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: 6 단계, 이미지 2/3 BOSE SoundTouch 30 Motherboard Replacement, Motherboard: 6 단계, 이미지 3/3
    • Remove the five 15.5 mm PH2 screws holding the motherboard down.
    • Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
    • Remove the motherboard.
    • The motherboard is identified as the smaller green board with an ethernet, USB Type A, and an auxiliary port.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Brennen Irey
회원 가입일: 04/18/18
1,065 평판
안내서 6개 작성하였습니다
Cal Poly, Team S16-G2, Livingston Spring 2018 Cal Poly, Team S16-G2, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S16G2
4 회원들
안내서 6개 작성하였습니다
댓글 3개
Where do I can get the power supply?
Ulises Peña - 답글
where can i get the notherboard? 354437-0060
guillermo gibson - 답글
Please where can I get the motherboard
Marjorie Newell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 17
30일 전: 78
전체 시간: 5,854
