주요 콘텐츠로 건너뛰기
BRCK v1 Modem Ribbon Connector Replacement
필요한 것
  1. BRCK v1 Modem Ribbon Connector Replacement, Top Cover: 1 단계, 이미지 1개 중 1개
    • Place the face of the device showing BRCK face up.
  2. BRCK v1 Modem Ribbon Connector Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  3. BRCK v1 Modem Ribbon Connector Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the top cover.
  4. BRCK v1 Modem Ribbon Connector Replacement, Modem: 4 단계, 이미지 1개 중 1개
    • Cut the black zip tie holding the modem down.
    • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
  5. BRCK v1 Modem Ribbon Connector Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the connection located on the edge of the modem.
  6. BRCK v1 Modem Ribbon Connector Replacement: 6 단계, 이미지 2개 중 1개 BRCK v1 Modem Ribbon Connector Replacement: 6 단계, 이미지 2개 중 2개
    • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
  7. BRCK v1 Modem Ribbon Connector Replacement: 7 단계, 이미지 3개 중 1개 BRCK v1 Modem Ribbon Connector Replacement: 7 단계, 이미지 3개 중 2개 BRCK v1 Modem Ribbon Connector Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
    • Lower the plate and gently pull the ribbon out of the face plate.
    • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
  8. BRCK v1 Modem Ribbon Connector Replacement: 8 단계, 이미지 2개 중 1개 BRCK v1 Modem Ribbon Connector Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the modem from the device.
  9. BRCK v1 Modem Ribbon Connector Replacement, Modem Ribbon Connector: 9 단계, 이미지 3개 중 1개 BRCK v1 Modem Ribbon Connector Replacement, Modem Ribbon Connector: 9 단계, 이미지 3개 중 2개 BRCK v1 Modem Ribbon Connector Replacement, Modem Ribbon Connector: 9 단계, 이미지 3개 중 3개
    • Using your fingers, apply equal force to each side of the black tab to loosen the connection.
    • Slide the ribbon out from under the black tab.
결론
작성자
3다른 기여자 명과 함께
Jeret Buerger
회원 가입일: 04/01/15
501 평판
안내서 5개를 작성함
Cal Poly, Team 12-3, Lancaster Spring 2015 Cal Poly, Team 12-3, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G3
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 8
전체 시간: 265
