주요 콘텐츠로 건너뛰기
BaByliss i-Pro 45 shaver battery Replacement
필요한 것
  1. BaByliss i-Pro 45 shaver battery Replacement, Remove the screws of the housing: 1 단계, 이미지 1개 중 1개
    • Remove the rubber plug hiding the screw
    • Remove the screw under the plug
    • Remove two screws below the blades with a long Philips screwdriver
  2. BaByliss i-Pro 45 shaver battery Replacement, Remove the blade (Optional): 2 단계, 이미지 2개 중 1개 BaByliss i-Pro 45 shaver battery Replacement, Remove the blade (Optional): 2 단계, 이미지 2개 중 2개
    • Remove the screws at the bottom of the blade
    • Remove the blade
  3. BaByliss i-Pro 45 shaver battery Replacement, Open the housing: 3 단계, 이미지 3개 중 1개 BaByliss i-Pro 45 shaver battery Replacement, Open the housing: 3 단계, 이미지 3개 중 2개 BaByliss i-Pro 45 shaver battery Replacement, Open the housing: 3 단계, 이미지 3개 중 3개
    • Gently open the housing
  4. BaByliss i-Pro 45 shaver battery Replacement, Lift the circuit: 4 단계, 이미지 2개 중 1개 BaByliss i-Pro 45 shaver battery Replacement, Lift the circuit: 4 단계, 이미지 2개 중 2개
    • open the plastic parts holding the circuit in place
    • start lifting from the tail
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Stanky
회원 가입일: 07/08/17
1,268 평판
안내서 6개를 작성함
댓글 14개
@fuss did you succeed?
Stanky - 답글
I haven’t bought the batteries yet. They were overpriced in my region (with shipping costs). For now, I use the shaver with leads connected.
Fuss -
Use low self-discharge NiMHs and it will make you angry many years.
Design of this cutter is faulty - it tugs your hair when you try to cut too much or too fast.
Leszek J - 답글
Personally, I have been using this hair clipper for many years and it works perfectly well. Today I have to replace the battery. Can anyone tell me what the battery model is and if I need to use a soldering iron to replace it?
JulienCharb - 답글
It is mentioned above:
3x AAA 1.2V batteries with U-lips are required to be soldered onto the motherboard.
So yes, a soldering iron is required, and the battery must have lips (i.e. not the standard AAA batteries you can find in any shop).
Fuss -
댓글 쓰기
조회 통계:
지난 24시간: 20
지난 7일: 131
지난 30일: 541
전체 시간: 18,048
