주요 콘텐츠로 건너뛰기
Baby Einstein Take Along Tunes Battery Socket Replacement
필요한 것
  1. Baby Einstein Take Along Tunes Battery Socket Replacement, Battery Socket: 1 단계, 이미지 1/1
    • Set the device on it's face with the back facing up.
  2. Baby Einstein Take Along Tunes Battery Socket Replacement: 2 단계, 이미지 1/1
    • Begin by removing all highlighted screws with a using a Phillips #1 Screwdriver.
  3. Baby Einstein Take Along Tunes Battery Socket Replacement: 3 단계, 이미지 1/1
    • Remove the battery plate with a plastic opening tool and set it aside.
  4. Baby Einstein Take Along Tunes Battery Socket Replacement: 4 단계, 이미지 1/1
    • Remove each battery with a plastic opening tool and set them aside.
  5. Baby Einstein Take Along Tunes Battery Socket Replacement: 5 단계, 이미지 1/1
    • Separate the device in two parts by using the plastic opening tool.
  6. Baby Einstein Take Along Tunes Battery Socket Replacement: 6 단계, 이미지 1/1
    • Remove the top piece and place it aside, keeping the bottom half with the mechanics.
  7. Baby Einstein Take Along Tunes Battery Socket Replacement: 7 단계, 이미지 1/1
    • Remove the highlighted screws using a Phillips #1 Screwdriver.
  8. Baby Einstein Take Along Tunes Battery Socket Replacement: 8 단계, 이미지 1/1
    • Use the plastic opening tool and carefully set the LED panel to the side, exposing the wires underneath.
  9. Baby Einstein Take Along Tunes Battery Socket Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • With the precision tweezers, straighten the metal connectors to remove the terminals from the other side.
  10. Baby Einstein Take Along Tunes Battery Socket Replacement: 10 단계, 이미지 1/2 Baby Einstein Take Along Tunes Battery Socket Replacement: 10 단계, 이미지 2/2
    • Sever the red wire from the metal connector with the precision tweezers.
  11. Baby Einstein Take Along Tunes Battery Socket Replacement: 11 단계, 이미지 1/2 Baby Einstein Take Along Tunes Battery Socket Replacement: 11 단계, 이미지 2/2
    • Sever the black wire from the metal connector with the precision tweezers.
  12. Baby Einstein Take Along Tunes Battery Socket Replacement: 12 단계, 이미지 1/2 Baby Einstein Take Along Tunes Battery Socket Replacement: 12 단계, 이미지 2/2
    • Flip the device on its face and remove the battery terminals with a metal spudger.
결론
Shreya Sunny
회원 가입일: 09/04/15
607 평판
안내서 6개 작성하였습니다
USF Tampa, Team 2-2, Sullivan Fall 2015 USF Tampa, Team 2-2, Sullivan Fall 2015 회원
USFT-SULLIVAN-F15S2G2
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 30
전체 시간: 618
