주요 콘텐츠로 건너뛰기
Back Cover Removal
필요한 것
  1. Back Cover Removal, Battery: 1 단계, 이미지 1/1
    • Turn the laptop face down to expose the back.
    • Locate the battery.
  2. Back Cover Removal: 2 단계, 이미지 1/3 Back Cover Removal: 2 단계, 이미지 2/3 Back Cover Removal: 2 단계, 이미지 3/3
    • Locate the battery latches. The battery latch mechanism can be compared to a door -- The right latch, when pushed right, unlocks the battery, while the left latch, when pushed left, releases the battery, pushing it out from its container.
    • Push the latch on the right to the right to unlock the battery latch locking mechanism.
    • Push the battery latch on the left to the left to unlock the battery.
  3. Back Cover Removal: 3 단계, 이미지 1/2 Back Cover Removal: 3 단계, 이미지 2/2
    • With the left battery latch pushed left, remove the battery from its port by lifting the battery from the middle of the battery.
    • The battery will come free.
  4. Back Cover Removal, Back Plate Removal: 4 단계, 이미지 1/3 Back Cover Removal, Back Plate Removal: 4 단계, 이미지 2/3 Back Cover Removal, Back Plate Removal: 4 단계, 이미지 3/3
    • Turn the laptop over to place it top down.
    • Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
    • Lift the back plate off the laptop, exposing the RAM and Hard Disk.
  5. Back Cover Removal, Optical Drive: 5 단계, 이미지 1/2 Back Cover Removal, Optical Drive: 5 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the single 3mm screw.
  6. Back Cover Removal: 6 단계, 이미지 1/2 Back Cover Removal: 6 단계, 이미지 2/2
    • Rotate the laptop so that you have access to the optical drive.
    • The optical drive is now only attached by a port in the drive's back. The optical drive can be pulled straight out of its housing.
    • Remove the drive.
  7. Back Cover Removal, Hard Drive: 7 단계, 이미지 1/2 Back Cover Removal, Hard Drive: 7 단계, 이미지 2/2
    • Unscrew the hard drive.
    • There could be up to five 3mm screws - One on each corner of the hard drive, and one at one end of the hard drive, attaching the drive to the laptop's frame.
    • Carefully push the hard drive away from its port. This should not require substantial force.
    • Lift the hard drive out.
    • Some hard drives have a plastic tab, which can be lifted from to remove the hard drive.
    • Otherwise, take hold of opposite sides of the hard drive and lift the drive straight up.
  8. Back Cover Removal, Back Cover Removal: 8 단계, 이미지 1/2 Back Cover Removal, Back Cover Removal: 8 단계, 이미지 2/2
    • Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver.
    • Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Monte Roden
회원 가입일: 02/14/18
465 평판
안내서 4개 작성하였습니다
Washington State, Team S1-G5, Lobnitz Spring 2018 Washington State, Team S1-G5, Lobnitz Spring 2018 회원
WSU-LOBNITZ-S18S1G5
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 54
전체 시간: 3,495
