소개
To gain access to many of the device components removal of the back cover is required.
필요한 것
Turn the laptop over to place it top down.
Use a Phillips #1 screwdriver to remove the screw holding in the back plate. This screw does not come out of the plate.
Lift the back plate off the laptop, exposing the RAM and Hard Disk.
Unscrew the hard drive.
Carefully push the hard drive away from its port. This should not require substantial force.
Lift the hard drive out.
Unscrew the screws circled in red. This includes eleven 6mm screws, and one 5mm screw underneath where the optical drive was housed. All screws can be removed with a Phillips #0 screwdriver.
Carefully remove the back cover. The battery holder contains notches that help hold the case in place, so take care not to break those.
다른 한 분이 해당 안내서를 완성하였습니다.
