주요 콘텐츠로 건너뛰기
Back Panel Replacement
필요한 것
  1. Back Panel Replacement, Back Panel: 1 단계, 이미지 1/3 Back Panel Replacement, Back Panel: 1 단계, 이미지 2/3 Back Panel Replacement, Back Panel: 1 단계, 이미지 3/3
    • First, remove the 6 screws in the back panel and pull the back panel off.
    • Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
  2. Back Panel Replacement: 2 단계, 이미지 1/3 Back Panel Replacement: 2 단계, 이미지 2/3 Back Panel Replacement: 2 단계, 이미지 3/3
    • Next, remove the rumble motor by unscrewing the 2 screws connecting it.
  3. Back Panel Replacement: 3 단계, 이미지 1/3 Back Panel Replacement: 3 단계, 이미지 2/3 Back Panel Replacement: 3 단계, 이미지 3/3
    • Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
결론
David Mistretta
회원 가입일: 10/26/16
101 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 UMass Dartmouth, Team 3-5, Isaacson Fall 2016 회원
UMASSD-ISAACSON-F16S3G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 332
