주요 콘텐츠로 건너뛰기
Back Panel
필요한 것
  1. Back Panel, Back Panel: 1 단계, 이미지 1개 중 1개
    • Flip the laptop so that the back is facing upwards.
    • Locate the small screw on the back that holds the "L" shaped panel.
    • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
  2. Back Panel: 2 단계, 이미지 3개 중 1개 Back Panel: 2 단계, 이미지 3개 중 2개 Back Panel: 2 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
    • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
  3. Back Panel: 3 단계, 이미지 1개 중 1개
    • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
결론
작성자
2다른 기여자 명과 함께
Meredith Shaffer
회원 가입일: 09/25/17
222 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 17
전체 시간: 734
