주요 콘텐츠로 건너뛰기
Back of Bookshelf Replacement
필요한 것
  1. Back of Bookshelf Replacement, Back of Bookshelf: 1 단계, 이미지 1/1
    • Gather all pieces of the bookshelf if it fell apart or the shelf itself is still together.
    • You will need two people to complete this project.
  2. Back of Bookshelf Replacement: 2 단계, 이미지 1/3 Back of Bookshelf Replacement: 2 단계, 이미지 2/3 Back of Bookshelf Replacement: 2 단계, 이미지 3/3
    • You will need to put the bookshelf back together by holding the sides together.
    • Drill new holes to insert new screws to reinforce the shelf. Use a 1/8 inch drill bit.
    • Put screws into the freshly made holes with 1/8 by 1 inch wood screws to bring it together.
  3. Back of Bookshelf Replacement: 3 단계, 이미지 1/3 Back of Bookshelf Replacement: 3 단계, 이미지 2/3 Back of Bookshelf Replacement: 3 단계, 이미지 3/3
    • Now that the base of the bookshelf is back together, we will need to measure out the size of board needed for the new backing.
    • Use the measuring tape and the square ruler to measure out the specific size you need. Use a pencil to draw the lines out so you can saw the piece out with precision.
    • Use the jig saw to cut the piece of plywood out following the lines you just drew.
  4. Back of Bookshelf Replacement: 4 단계, 이미지 1/3 Back of Bookshelf Replacement: 4 단계, 이미지 2/3 Back of Bookshelf Replacement: 4 단계, 이미지 3/3
    • Line your new piece of plywood that you just cut, up with the back of the bookshelf.
    • Make sure that the corners are lined up so that as you hammer in the nails it stays lined up and even.
  5. Back of Bookshelf Replacement: 5 단계, 이미지 1/2 Back of Bookshelf Replacement: 5 단계, 이미지 2/2
    • Start from the top and work your way down each side when putting the nails in so the board doesn't bow.
    • Use 2d penny nails and hammer them in along all four sides.
    • Five nails on each of the four sides is all you will need.
  6. Back of Bookshelf Replacement: 6 단계, 이미지 1/2 Back of Bookshelf Replacement: 6 단계, 이미지 2/2
    • The shelf has its new plywood backing, so you can stand it up and you will feel the immediate difference in the sturdiness of your new shelf.
    • Place the shelf in the room of your choosing and place your books on it, knowing that it will not fall apart.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Melissa Miller
회원 가입일: 03/07/19
187 평판
안내서 1개 작성함
Missouri Western, Team S1-G1, Cools Stephens Spring 2019 Missouri Western, Team S1-G1, Cools Stephens Spring 2019 회원
MWSU-COOLS STEPHENS-S19S1G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 40
30일 전: 164
전체 시간: 9,688
