주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Backbone One Left Bumper Replacement
필요한 것
  1. Backbone One Left Bumper Replacement, Unfasten the screws: 1 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    댓글 쓰기
  2. Backbone One Left Bumper Replacement, Rotate the upper cover: 2 단계, 이미지 3개 중 1개 Backbone One Left Bumper Replacement, Rotate the upper cover: 2 단계, 이미지 3개 중 2개 Backbone One Left Bumper Replacement, Rotate the upper cover: 2 단계, 이미지 3개 중 3개
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
    댓글 쓰기
  3. Backbone One Left Bumper Replacement, Remove the protective tape: 3 단계, 이미지 3개 중 1개 Backbone One Left Bumper Replacement, Remove the protective tape: 3 단계, 이미지 3개 중 2개 Backbone One Left Bumper Replacement, Remove the protective tape: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
    댓글 쓰기
  4. Backbone One Left Bumper Replacement, Open the ZIF connector: 4 단계, 이미지 2개 중 1개 Backbone One Left Bumper Replacement, Open the ZIF connector: 4 단계, 이미지 2개 중 2개
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
    댓글 쓰기
  5. Backbone One Left Bumper Replacement, Disconnect the interconnect cable: 5 단계, 이미지 2개 중 1개 Backbone One Left Bumper Replacement, Disconnect the interconnect cable: 5 단계, 이미지 2개 중 2개
    • Use your fingers to disconnect the interconnect cable from its connector.
    댓글 쓰기
  6. Backbone One Left Bumper Replacement: 6 단계, 이미지 2개 중 1개 Backbone One Left Bumper Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the upper half of the left controller assembly.
    댓글 쓰기
  7. Backbone One Left Bumper Replacement, Remove the screw: 7 단계, 이미지 2개 중 1개 Backbone One Left Bumper Replacement, Remove the screw: 7 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
    댓글 쓰기
  8. Backbone One Left Bumper Replacement, Remove the trigger: 8 단계, 이미지 2개 중 1개 Backbone One Left Bumper Replacement, Remove the trigger: 8 단계, 이미지 2개 중 2개
    • Remove the left trigger.
    댓글 쓰기
  9. Backbone One Left Bumper Replacement, Remove the bumper: 9 단계, 이미지 2개 중 1개 Backbone One Left Bumper Replacement, Remove the bumper: 9 단계, 이미지 2개 중 2개
    • Use your fingers to remove the left bumper.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
67,088 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 25,937개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 59
전체 시간: 1,381
