주요 콘텐츠로 건너뛰기
Backbone One Left Trigger Replacement
필요한 것
  1. Backbone One Left Trigger Replacement, Unfasten the screws: 1 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Left Trigger Replacement, Rotate the upper cover: 2 단계, 이미지 3개 중 1개 Backbone One Left Trigger Replacement, Rotate the upper cover: 2 단계, 이미지 3개 중 2개 Backbone One Left Trigger Replacement, Rotate the upper cover: 2 단계, 이미지 3개 중 3개
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. Backbone One Left Trigger Replacement, Remove the protective tape: 3 단계, 이미지 3개 중 1개 Backbone One Left Trigger Replacement, Remove the protective tape: 3 단계, 이미지 3개 중 2개 Backbone One Left Trigger Replacement, Remove the protective tape: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. Backbone One Left Trigger Replacement, Open the ZIF connector: 4 단계, 이미지 2개 중 1개 Backbone One Left Trigger Replacement, Open the ZIF connector: 4 단계, 이미지 2개 중 2개
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. Backbone One Left Trigger Replacement, Disconnect the interconnect cable: 5 단계, 이미지 2개 중 1개 Backbone One Left Trigger Replacement, Disconnect the interconnect cable: 5 단계, 이미지 2개 중 2개
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. Backbone One Left Trigger Replacement: 6 단계, 이미지 2개 중 1개 Backbone One Left Trigger Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the upper half of the left controller assembly.
  7. Backbone One Left Trigger Replacement, Remove the screw: 7 단계, 이미지 2개 중 1개 Backbone One Left Trigger Replacement, Remove the screw: 7 단계, 이미지 2개 중 2개
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
  8. Backbone One Left Trigger Replacement, Remove the trigger: 8 단계, 이미지 2개 중 1개 Backbone One Left Trigger Replacement, Remove the trigger: 8 단계, 이미지 2개 중 2개
    • Remove the left trigger.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
62,148 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
1가이드 댓글
Where can I buy the trigger
Zach - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 60
전체 시간: 3,455
