주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Backbone One Phone Connector Replacement
필요한 것
  1. Backbone One Phone Connector Replacement, Remove the screws: 1 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Phone Connector Replacement, Rotate the upper part: 2 단계, 이미지 3개 중 1개 Backbone One Phone Connector Replacement, Rotate the upper part: 2 단계, 이미지 3개 중 2개 Backbone One Phone Connector Replacement, Rotate the upper part: 2 단계, 이미지 3개 중 3개
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
  3. Backbone One Phone Connector Replacement, Remove the screws: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the two 4.8 mm-long screws securing the phone connector.
  4. Backbone One Phone Connector Replacement, Unthread the phone connector: 4 단계, 이미지 3개 중 1개 Backbone One Phone Connector Replacement, Unthread the phone connector: 4 단계, 이미지 3개 중 2개 Backbone One Phone Connector Replacement, Unthread the phone connector: 4 단계, 이미지 3개 중 3개
    • Use your fingers to thread the phone connecter through the opening in the plastic cover at the right side of the rear cover.
  5. Backbone One Phone Connector Replacement, Disconnect the phone connector cable: 5 단계, 이미지 2개 중 1개 Backbone One Phone Connector Replacement, Disconnect the phone connector cable: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to disconnect the first phone connector cable from the mainboard.
  6. Backbone One Phone Connector Replacement, Disconnect the phone connector cable: 6 단계, 이미지 2개 중 1개 Backbone One Phone Connector Replacement, Disconnect the phone connector cable: 6 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to disconnect the second phone connector cable from the mainboard.
  7. Backbone One Phone Connector Replacement, Remove the phone connector cable: 7 단계, 이미지 1개 중 1개
    • Remove the phone connector cable.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Adriana Zwink
회원 가입일: 12/18/19
66,732 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 25,685개를 작성함
6가이드 댓글
Where can i buy a new part
reye_s - 답글 공유
Unfortunately we haven't found any replacement parts yet. If you find a website that offers replacement parts feel free to share your experience with us.
Adriana Zwink - 답글 공유
Where can I find the connector
Big_deppresion_time_14 Xxx - 답글 공유
My son bent the connector cable. Where do I buy a new one?
Please update as soon as possible!
Krystal Glavic - 답글 공유
Has anyone found a place to buy a replacement lightning connector yet?
Ump_ - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 35
지난 30일: 178
전체 시간: 6,056
