주요 콘텐츠로 건너뛰기
Backbone One Right Bumper Replacement
필요한 것
  1. Backbone One Right Bumper Replacement, Remove the screws: 1 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Right Bumper Replacement, Rotate the upper part: 2 단계, 이미지 3개 중 1개 Backbone One Right Bumper Replacement, Rotate the upper part: 2 단계, 이미지 3개 중 2개 Backbone One Right Bumper Replacement, Rotate the upper part: 2 단계, 이미지 3개 중 3개
    • Lift up the upper cover of the controller.
    • Swing the upper cover over and place it on the controller case.
    • Make sure that the interconnecting cable has no tension.
  3. Backbone One Right Bumper Replacement, Remove the protective tape: 3 단계, 이미지 3개 중 1개 Backbone One Right Bumper Replacement, Remove the protective tape: 3 단계, 이미지 3개 중 2개 Backbone One Right Bumper Replacement, Remove the protective tape: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
  4. Backbone One Right Bumper Replacement, Open the interconnect cable ZIF connector: 4 단계, 이미지 3개 중 1개 Backbone One Right Bumper Replacement, Open the interconnect cable ZIF connector: 4 단계, 이미지 3개 중 2개 Backbone One Right Bumper Replacement, Open the interconnect cable ZIF connector: 4 단계, 이미지 3개 중 3개
    • Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
  5. Backbone One Right Bumper Replacement, Disconnect the interconnect cable: 5 단계, 이미지 2개 중 1개 Backbone One Right Bumper Replacement, Disconnect the interconnect cable: 5 단계, 이미지 2개 중 2개
    • Disconnect the cable by pulling it straight out the ZIF connector.
  6. Backbone One Right Bumper Replacement, Disconnect the phone connector cables: 6 단계, 이미지 3개 중 1개 Backbone One Right Bumper Replacement, Disconnect the phone connector cables: 6 단계, 이미지 3개 중 2개 Backbone One Right Bumper Replacement, Disconnect the phone connector cables: 6 단계, 이미지 3개 중 3개
    • Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
  7. Backbone One Right Bumper Replacement, Separate the upper case: 7 단계, 이미지 1개 중 1개
    • Separate the the upper case of the left controller handle.
  8. Backbone One Right Bumper Replacement, Remove the screws: 8 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 5.9 mm-long screws.
  9. Backbone One Right Bumper Replacement, Remove the trigger: 9 단계, 이미지 2개 중 1개 Backbone One Right Bumper Replacement, Remove the trigger: 9 단계, 이미지 2개 중 2개
    • Remove the trigger.
  10. Backbone One Right Bumper Replacement, Remove the bumper: 10 단계, 이미지 2개 중 1개 Backbone One Right Bumper Replacement, Remove the bumper: 10 단계, 이미지 2개 중 2개
    • Remove the bumper.
결론
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
회원 가입일: 12/18/19
62,414 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,738개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 15
전체 시간: 612
