이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Use this guide to replace the right trigger on your Backbone One.
필요한 것
Lift up the upper cover of the controller.
Swing the upper cover over and place it on the controller case.
Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
Disconnect the cable by pulling it straight out the ZIF connector.
Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
Opening didn’t go as planned? Answers community for help.
댓글 2개
where can I buy a right trigger replacement?
