이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Lift up the upper cover of the controller.
Swing the upper cover over and place it on the controller case.
Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable and the connector.
Use the tip of an opening pick to open the gray flap of the interconnect cable ZIF connector by pushing it upwards.
Use a pair of tweezers to disconnect the phone connector cables out from their sockets.
댓글 2개
where can I buy a right trigger replacement?
