소개
A broken pawl, where unnatural grooves have been made, can cause the line to get caught and start spooling on the side. This is a guide on how to easily replace a baitcasting fishing reel's pawl so you can get right back to fishing.
Before starting, make sure you have a spare pawl for the reel's specific brand on hand to make the process smoother as most pawls are not interchangeable.
필요한 것
이 단계에 사용된 도구:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 2.5 mm flathead screwdriver to remove the pawl cap on the body of the reel.
거의 끝나갑니다!
Happy fishing!
결론
Happy fishing!
다른 한 분이 해당 안내서를 완성하였습니다.
