주요 콘텐츠로 건너뛰기
Barbie Doll Hair Replacement
필요한 것
  1. Barbie Doll Hair Replacement, Barbie Doll Hair: 1 단계, 이미지 1/3 Barbie Doll Hair Replacement, Barbie Doll Hair: 1 단계, 이미지 2/3 Barbie Doll Hair Replacement, Barbie Doll Hair: 1 단계, 이미지 3/3
    • Use light force to pull barbie head off of the body.
    • If stuck, soak in warm water to loosen.
  2. Barbie Doll Hair Replacement: 2 단계, 이미지 1/2 Barbie Doll Hair Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Cut off all of the remaining hair using scissors.
    • Tweezers may be used once hair is too short for scissors.
    • It is important to remove as much hair as possible.
  3. Barbie Doll Hair Replacement: 3 단계, 이미지 1/3 Barbie Doll Hair Replacement: 3 단계, 이미지 2/3 Barbie Doll Hair Replacement: 3 단계, 이미지 3/3
    • Cut the yarn pieces for doll hair.
    • With a ruler, measure equal pieces twice as long as intended hair length.
    • Cut enough for desired hair thickness.
    • To make up for inconsistencies in length, you may cut pieces longer and trim later.
  4. Barbie Doll Hair Replacement: 4 단계, 이미지 1/3 Barbie Doll Hair Replacement: 4 단계, 이미지 2/3 Barbie Doll Hair Replacement: 4 단계, 이미지 3/3
    • Thread yarn between the forked tip of the reroot tool.
    • Attempt to thread the yarn at its midpoint for more even hair.
    • Insert the reroot tool into a small hole atop the doll's head.
    • Push the yarn inside as far as the tool will allow.
    • Remove the reroot tool from the head, leaving the yarn tucked inside.
  5. Barbie Doll Hair Replacement: 5 단계, 이미지 1/1
    • Add glue to the inside of the doll's head.
    • Plug in and preheat the glue gun.
    • Insert glue gun from the base of the head.
    • Add a thicker layer of glue for stronger hair.
    • Hot glue can cause burns when exposed directly to skin.
  6. Barbie Doll Hair Replacement: 6 단계, 이미지 1/1
    • After applying glue, use the blunt end of the rerooting tool to spread glue to cover the inside of the head.
    • Do this immediately after applying glue, because it will dry quickly.
  7. Barbie Doll Hair Replacement: 7 단계, 이미지 1/2 Barbie Doll Hair Replacement: 7 단계, 이미지 2/2
    • Wait for the glue to dry (15-30 minutes).
    • Once the glue is dry, attach the Barbie head back onto the neck joint.
    • For extra styling and volume, you may separate yarn strands.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Miranda Comstock
회원 가입일: 01/31/23
170 평판
안내서 1개 작성함
UC Davis, Team 2-3, Andersen Winter 2023 UC Davis, Team 2-3, Andersen Winter 2023 회원
UCD-ANDERSEN-W23S2G3
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 21
30일 전: 94
전체 시간: 1,626
