주요 콘텐츠로 건너뛰기
Base Metal Bezel Watch Stainless Steel Back 2103 Battery Replacement
필요한 것
  1. Base Metal Bezel Watch Stainless Steel Back 2103 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Use a spudger to pry the backing up from the watch.
  2. Base Metal Bezel Watch Stainless Steel Back 2103 Battery Replacement: 2 단계, 이미지 1/1
    • Remove the old watch battery from the back carefully with your spudger.
  3. Base Metal Bezel Watch Stainless Steel Back 2103 Battery Replacement: 3 단계, 이미지 1/1
    • Replace your old battery with a brand-new battery. Use your spudger to put the brand-new battery into place.
  4. Base Metal Bezel Watch Stainless Steel Back 2103 Battery Replacement: 4 단계, 이미지 1/1
    • After replacing the battery, put the backing back on and you should have yourself a working watch.
결승점
Thomias Hughes
회원 가입일: 03/29/23
159 평판
안내서 1개 작성함
University of Memphis, Team 1-1, Peters Spring 2023 University of Memphis, Team 1-1, Peters Spring 2023 회원
UM-PETERS-S23S1G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 64
전체 시간: 812
