소개
If your Base Metal Bezel Watch Stainless Steel Back 2103 watch is not working properly and the hands of the clock are not moving, you most likely have a dead battery that needs a replacement. A working battery will give your watch a new life. In due course, your watch will tend to go out and it can last up to a couple of years.
If you like, when removing the back of the watch you can put on gloves for safety precautions to avoid hurting yourselves. Also, have good lighting so you can see what you are doing. Never work in a dark environment while doing repairs.
필요한 것
거의 끝나갑니다!
결승점
