주요 콘텐츠로 건너뛰기
Basic cleaning for the A1048 Keyboard
  1. Basic cleaning for the A1048 Keyboard, Starting info: 1 단계, 이미지 1/1
    • Start with your dirty keyboard, most likely found from a 2003-2007 white iMac.
    • This may void any warranty the keyboard may have. Proceed with caution.
  2. Basic cleaning for the A1048 Keyboard, Keycap removal: 2 단계, 이미지 1/2 Basic cleaning for the A1048 Keyboard, Keycap removal: 2 단계, 이미지 2/2
    • Pull off keycaps
    • Repeat until there is none left
    • Be sure to keep metal braces where they are in the keys, as otherwise the keys will be unstable after restoration.
  3. Basic cleaning for the A1048 Keyboard, Base keyboard cleaning: 3 단계, 이미지 1/2 Basic cleaning for the A1048 Keyboard, Base keyboard cleaning: 3 단계, 이미지 2/2
    • Use a vacuum cleaner and q-tip to remove dust/debris hidden underneath the keyboard.
  4. Basic cleaning for the A1048 Keyboard, Keycap cleaning: 4 단계, 이미지 1/3 Basic cleaning for the A1048 Keyboard, Keycap cleaning: 4 단계, 이미지 2/3 Basic cleaning for the A1048 Keyboard, Keycap cleaning: 4 단계, 이미지 3/3
    • Individually clean each key until they reach their former white glory.
    • If your keys are yellowed, you can 'retrobright' them removing any yellow caused by the sun. There are many tutorials online showing you how to do this.
    • It may be easier to fill a bowl with soapy hot water and dump all of the keys in to clean unreachable areas.
    • Dry each keycap ready for installation.
  5. Basic cleaning for the A1048 Keyboard, Replacing the keys: 5 단계, 이미지 1/2 Basic cleaning for the A1048 Keyboard, Replacing the keys: 5 단계, 이미지 2/2
    • Insert each key by pressing down onto its hole on the keyboard.
    • Refer to Step 1’s image if you cannot remember where some of the keys go.
    • Start with shortcut keys (Command, control, function, esc, space, arrow keys etc) and work your way into the letters.
    • Line up the metal braces back with their slots they came out from as shown in image #2.
  6. Basic cleaning for the A1048 Keyboard, Completion!: 6 단계, 이미지 1/1
    • If you followed the steps correctly, you will have a clean keyboard ready for its Mac!
    • This keyboard will work with new Macs if you do not have an official keyboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Joshua Lockett
회원 가입일: 07/23/18
283 평판
안내서 1개 작성함
댓글 3개
If you read some advice recommending to use silicon oil to soft keys, NEVER DO IT!!! Ok, it softs the key, but it is extremely dangerous, because oil can generate malfunctioning if reaches conductive board. If you do it anyway, try to apply it with a brush instead of directly and NEVER inside de hole where the membrane is. Always OUTSIDE sides.
Instead of that, I recommend a small brush and in the bottom part of keys, apply dry wax (yes, the same than surfers use for their boards!) If you apply properly, keys will be quiet and smooth like first day.
flyriviera - 답글
does the official keyboard work with new macs?
Aaditya Mali - 답글
Yes, it works on my MacBook Air M2, but I haven't test the USB port on keyboard yet.
imjeremysome -
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 34
30일 전: 138
전체 시간: 6,105
