주요 콘텐츠로 건너뛰기
Basis Peak Band Replacement
필요한 것
  1. Basis Peak Band Replacement, Band: 1 단계, 이미지 1/1
    • Flip the watch over to view the back panel and sensor. Arrange the watch so that the band clasp is away from you.
    • Keep the watch in this position to help you follow the rest of the guide.
  2. Basis Peak Band Replacement: 2 단계, 이미지 1/1
    • Release the spring latches on the underside of each band to remove the bands from the frame.
결론
To reattach the bands, follow these instructions in reverse order.
Alexander Halliwell
회원 가입일: 03/26/17
213 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S4-G4, Julie Spring 2017 UMass Dartmouth, Team S4-G4, Julie Spring 2017 회원
UMASSD-JULIE-S17S4G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 8
전체 시간: 191
