주요 콘텐츠로 건너뛰기
Basis Peak Frame Replacement
필요한 것
  1. Basis Peak Frame Replacement, Frame: 1 단계, 이미지 1/1
    • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
    • Maintain this orientation to follow the guide.
  2. Basis Peak Frame Replacement: 2 단계, 이미지 1/2 Basis Peak Frame Replacement: 2 단계, 이미지 2/2
    • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
  3. Basis Peak Frame Replacement: 3 단계, 이미지 1/1
    • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
  4. Basis Peak Frame Replacement: 4 단계, 이미지 1/1
    • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
    • The clips have small lips that you can put the spudger under to get more leverage.
    • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
결론
Alexander Halliwell
회원 가입일: 03/26/17
213 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S4-G4, Julie Spring 2017 UMass Dartmouth, Team S4-G4, Julie Spring 2017 회원
UMASSD-JULIE-S17S4G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 10
전체 시간: 165
