주요 콘텐츠로 건너뛰기
Bassoon Whisper Key Pad Replacement
필요한 것
  1. Bassoon Whisper Key Pad Replacement, Key Pad: 1 단계, 이미지 2개 중 1개 Bassoon Whisper Key Pad Replacement, Key Pad: 1 단계, 이미지 2개 중 2개
    • Assess the damage to the whisper key. If the bocal is digging into the whisper key pad, gently swivel it away from the whisper key pad.
    • If the whisper key pad is completely missing, skip to step 4.
    • Make sure the area around the key pad is clear before proceeding.
  2. Bassoon Whisper Key Pad Replacement: 2 단계, 이미지 3개 중 1개 Bassoon Whisper Key Pad Replacement: 2 단계, 이미지 3개 중 2개 Bassoon Whisper Key Pad Replacement: 2 단계, 이미지 3개 중 3개
    • Check to make sure the whisper key lock is disengaged. If the whisper key lock is engaged, gently pull back on the tab to release the lock, returning the whisper key to its place.
  3. Bassoon Whisper Key Pad Replacement: 3 단계, 이미지 2개 중 1개 Bassoon Whisper Key Pad Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the bocal while making sure to stay clear of the whisper key.
  4. Bassoon Whisper Key Pad Replacement: 4 단계, 이미지 1개 중 1개
    • Take apart the bassoon and place the wing joint on a flat surface.
    • Make sure the whisper key is facing up.
  5. Bassoon Whisper Key Pad Replacement: 5 단계, 이미지 2개 중 1개 Bassoon Whisper Key Pad Replacement: 5 단계, 이미지 2개 중 2개
    • Take a flat screwdriver and remove the old glue from the key.
  6. Bassoon Whisper Key Pad Replacement: 6 단계, 이미지 1개 중 1개
    • If the key pad is still partially attached to the key, use the screwdriver to gently make space between the key and the key pad. Pour a small amount of super glue into this space.
    • If the whisper key pad has completely come off of the key, place a drop of super glue in the middle of the key. Place a new key pad on top of the glue.
  7. Bassoon Whisper Key Pad Replacement: 7 단계, 이미지 2개 중 1개 Bassoon Whisper Key Pad Replacement: 7 단계, 이미지 2개 중 2개
    • Gently press down on the key pad, ensuring that the glue does not spill out from the sides. If the glue does spill, wipe off the excess with a paper towel.
    • At this point, the instrument can be played again, but the key pad will not set until the glue has dried.
결승점
작성자
1다른 기여자 명과 함께
Sonakshi Bhatia
회원 가입일: 05/29/24
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 29
전체 시간: 262
