소개
There are two kinds of replacement slides: ball bearing and roller slides. The ball-bearing slides are the most frequent, whereas the roller slides are utilized for heavier drawers. I shall utilize ball-bearing drops in this tutorial since they are quiet and smooth. Although drawer slides are meant to be sturdy and last a lifetime, it may be essential to replace them on sometimes. With this article, I will demonstrate the simplest method to repair your drawer slides if they get worn or if the weight of the drawer prevents it from functioning effectively.
필요한 것
Before starting, remove the existing sliders and brackets by unscrewing the screws in a counterclockwise direction.
Enjoy your new drawer!
다른 한 분이 해당 안내서를 완성하였습니다.
