주요 콘텐츠로 건너뛰기
Bathroom Drawer Slide Replacement
필요한 것
  1. Bathroom Drawer Slide Replacement, Slide Replacement: 1 단계, 이미지 1/2 Bathroom Drawer Slide Replacement, Slide Replacement: 1 단계, 이미지 2/2
    • Before starting, remove the existing sliders and brackets by unscrewing the screws in a counterclockwise direction.
  2. Bathroom Drawer Slide Replacement: 2 단계, 이미지 1/1
    • Measurements are crucial to starting when inserting a new drawer slide replacement.
    • Be sure to measure the inside of the drawer with a measuring tape to see its distance on how long the drawer slide must be.
  3. Bathroom Drawer Slide Replacement: 3 단계, 이미지 1/1
    • Another critical measurement is the width of which the drawer must be fit. Make sure your measurements are correct with the width needed for the drawer.
  4. Bathroom Drawer Slide Replacement: 4 단계, 이미지 1/1
    • Now it is time to insert the drawer insert inside; ensure that the holes align with the insert, and be very cautious with the screw and screwdriver.
  5. Bathroom Drawer Slide Replacement: 5 단계, 이미지 1/1
    • This step requires your screwdriver, which is needed to insert the screw into the hole when inserting the drawer slide. Ensure the screw is tight and secure before inserting it into the drawer wall.
  6. Bathroom Drawer Slide Replacement: 6 단계, 이미지 1/1
    • As soon as the correct measurements and screw are inserted into the drawer slide, it is time to insert the drawer slide with the screw.
    • Be very cautious, and do not rush this step. Turn the screwdriver in a clockwise direction to tighten the screw.
  7. Bathroom Drawer Slide Replacement: 7 단계, 이미지 1/1
    • Now that the drawer slide is inserted, it is time to insert the drawer slide supporter that is needed for the drawers not to get scratched and damaged. This step requires a screwdriver.
  8. Bathroom Drawer Slide Replacement: 8 단계, 이미지 1/1
    • It is time to insert the drawer, be very cautious with this step, and be sure not to damage it. Insert it slowly by latching it upon the drawer slide and pushing forward for the drawer to slide in.
  9. Bathroom Drawer Slide Replacement: 9 단계, 이미지 1/1
    • When the drawer is inside the drawer slide insert, use the clamps to secure the drawer, so the drawer will not latch out and fall out of the drawer slide.
  10. Bathroom Drawer Slide Replacement: 10 단계, 이미지 1/1
    • As soon as all steps are complete, it is now time to push in your drawer; with no damage to the cabinets, the drawer will slide in easily.
결론
Enjoy your new drawer!
다른 한 분이 해당 안내서를 완성하였습니다.
Adam J Acosta
회원 가입일: 08/22/22
181 평판
안내서 1개 작성함
CSU Los Angeles, Team 1-77, Briggs Fall 2022 CSU Los Angeles, Team 1-77, Briggs Fall 2022 회원
CSULA-BRIGGS-F22S1G77
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 32
전체 시간: 615
