주요 콘텐츠로 건너뛰기
Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta"
필요한 것
  1. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta", Knobs: 1 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta", Knobs: 1 단계, 이미지 2/2
    • Underneath the sink there are two valves that supply water to each knob. Turn off the supply by twisting the valves tightly to the right.
    • The water supply needs to be off before starting the replacement. Failure to do so can result in water spouting all over the area, causing damage.
  2. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 2 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 2 단계, 이미지 2/2
    • Double-check that the water supply is off by twisting the faucet knobs to the left.
  3. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 3 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 3 단계, 이미지 2/2
    • With the 1/8” flathead screwdriver, insert through the groove on the edge of the hot-n-cold caps, loosen, and remove them.
  4. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 4 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 4 단계, 이미지 2/2
    • Using the PZ1 starhead screwdriver, loosen the 19.1 mm oval head screw.
  5. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 5 단계, 이미지 1/3 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 5 단계, 이미지 2/3 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 5 단계, 이미지 3/3
    • Remove the 19.1 mm oval head screw by pulling it up from the knob.
    • Lift the knob from the faucet to remove it.
  6. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 6 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 6 단계, 이미지 2/2
    • Use an adjustable wrench to loosen the bonnet nut.
  7. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 7 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 7 단계, 이미지 2/2
    • Remove the bonnet nut from the faucet.
  8. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 8 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 8 단계, 이미지 2/2
    • Remove the escutcheon by pulling it out from the valve.
  9. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 9 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 9 단계, 이미지 2/2
    • Place the new escutcheon by pushing it down into the valve.
  10. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 10 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 10 단계, 이미지 2/2
    • Install the new bonnet nut by placing it over and around the escutcheon.
  11. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 11 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 11 단계, 이미지 2/2
    • Using an adjustable wrench, tighten the bonnet nut by twisting it to the right.
  12. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 12 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 12 단계, 이미지 2/2
    • Install the new knob by placing it on top and around the escutcheon and bonnet nut.
  13. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 13 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 13 단계, 이미지 2/2
    • Insert the 19.1 mm oval head screw into the top of the knob.
  14. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 14 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 14 단계, 이미지 2/2
    • Using the PZ1 starhead screwdriver, tighten the screw by twisting it to the right.
  15. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 15 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 15 단계, 이미지 2/2
    • Install the new hot-n-cold caps by snapping them onto the top of the knobs.
  16. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 16 단계, 이미지 1/2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": 16 단계, 이미지 2/2
    • Turn on the water supply by twisting the valves to the left.
결론
Test that the replacement was done correctly and that the water supply is on by twisting the faucet knobs to the right. Enjoy your new remodeled faucet!
다른 한 분이 해당 안내서를 완성하였습니다.
Benjamin Figueroa
회원 가입일: 09/23/23
295 평판
안내서 1개 작성함
Austin Community College, Team 1-5, Watkins Fall 2023 Austin Community College, Team 1-5, Watkins Fall 2023 회원
AUSTINCC-WATKINS-F23S1G5
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 27
전체 시간: 157
