주요 콘텐츠로 건너뛰기
Batteries in Nikon Coolpix 4600 Replacement
필요한 것
  1. Batteries in Nikon Coolpix 4600 Replacement, Batteries: 1 단계, 이미지 1/1
    • Locate the battery compartment on the bottom right of the camera.
  2. Batteries in Nikon Coolpix 4600 Replacement: 2 단계, 이미지 1/2 Batteries in Nikon Coolpix 4600 Replacement: 2 단계, 이미지 2/2
    • While holding the camera with the lens facing toward you, slide the lock button to the right and pull the battery door towards you. The battery door should pop open.
    • If the door does not pop open, gently lift the door using your finger.
  3. Batteries in Nikon Coolpix 4600 Replacement: 3 단계, 이미지 1/1
    • Remove the dead batteries. The easiest way to do this is by turning the camera right side up and gently tapping the lens side of the camera against your hand until they fall out. If this does not work, you can simply pull them out.
  4. Batteries in Nikon Coolpix 4600 Replacement: 4 단계, 이미지 1/1
    • Insert fresh AA batteries into the compartment as demonstrated in the picture to the left. The orientation of the batteries is important to ensure the camera works properly.
    • Close the battery door.
    • Remember to slide the switch back into the lock position.
결론
Reassembly of the camera is the final step in the guide.
Richard
회원 가입일: 04/19/12
9 평판
안내서 1개 작성함
Cal Poly, Team 9-43, Regan Spring 2012 Cal Poly, Team 9-43, Regan Spring 2012 회원
CPSU-REGAN-S12S9G43
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 21
30일 전: 71
전체 시간: 2,879
