주요 콘텐츠로 건너뛰기
Battery Disconnect
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. Battery Disconnect, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 1개 Battery Disconnect, Prepare your laptop for disassembly: 1 단계, 이미지 2개 중 2개
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Battery Disconnect, Unfasten the back cover: 2 단계, 이미지 2개 중 1개 Battery Disconnect, Unfasten the back cover: 2 단계, 이미지 2개 중 2개
    • Use a T5 Torx driver to remove the ten 3.8 mm‑long screws securing the back cover.
  3. Battery Disconnect, Insert an opening pick: 3 단계, 이미지 3개 중 1개 Battery Disconnect, Insert an opening pick: 3 단계, 이미지 3개 중 2개 Battery Disconnect, Insert an opening pick: 3 단계, 이미지 3개 중 3개
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If it feels loose, remove it at any time.
    • Apply a suction handle to the middle of the back cover's right edge, between the lower rubber foot and the middle screws.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Battery Disconnect, Angle the opening pick: 4 단계, 이미지 3개 중 1개 Battery Disconnect, Angle the opening pick: 4 단계, 이미지 3개 중 2개 Battery Disconnect, Angle the opening pick: 4 단계, 이미지 3개 중 3개
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
  5. Battery Disconnect, Free the bottom right corner: 5 단계, 이미지 3개 중 1개 Battery Disconnect, Free the bottom right corner: 5 단계, 이미지 3개 중 2개 Battery Disconnect, Free the bottom right corner: 5 단계, 이미지 3개 중 3개
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Battery Disconnect, Free the front edge: 6 단계, 이미지 3개 중 1개 Battery Disconnect, Free the front edge: 6 단계, 이미지 3개 중 2개 Battery Disconnect, Free the front edge: 6 단계, 이미지 3개 중 3개
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame completely.
  7. Battery Disconnect, Remove the back cover: 7 단계, 이미지 3개 중 1개 Battery Disconnect, Remove the back cover: 7 단계, 이미지 3개 중 2개 Battery Disconnect, Remove the back cover: 7 단계, 이미지 3개 중 3개
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the thermal pads.
  8. Battery Disconnect, Disconnect the battery: 8 단계, 이미지 3개 중 1개 Battery Disconnect, Disconnect the battery: 8 단계, 이미지 3개 중 2개 Battery Disconnect, Disconnect the battery: 8 단계, 이미지 3개 중 3개
    • Insert the point of a spudger under the middle of the battery connector's long edge.
    • Lift and disconnect the battery press connector from its socket on the motherboard.
    • This will require some force. Don't pry against any resistors or chips.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
결론
Spencer Day
회원 가입일: 09/14/22
150,248 평판
안내서 995개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,649개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 49
