주요 콘텐츠로 건너뛰기
Battery Replacement for the Kindle 4
필요한 것
  1. Battery Replacement for the Kindle 4, Opening the case: 1 단계, 이미지 2개 중 1개 Battery Replacement for the Kindle 4, Opening the case: 1 단계, 이미지 2개 중 2개
    • Use plastic opening tools to pry open the case starting on the long side. The cover has a total of 8 clips, 4 of which (located on the long sides) are designed so they will be damaged when the device is opened.
  2. Battery Replacement for the Kindle 4, Loosening the adhesive: 2 단계, 이미지 1개 중 1개
    • After prying open 3 sides of the cover, it is still attached to the aluminium cover by double-sided adhesive tape. Use a screwdriver to create a small gap and use the scalpel to cut the adhesive. Alternatively you can losen the adhesive with a heat gun.
  3. Battery Replacement for the Kindle 4, Remove the case cover: 3 단계, 이미지 1개 중 1개
    • After loosening the adhesive, the case cover can be easily removed.
  4. Battery Replacement for the Kindle 4, Remove the battery cover: 4 단계, 이미지 1개 중 1개
    • Remove the two TX5 screws from the battery cover.
  5. Battery Replacement for the Kindle 4, Remove any adhesive residue: 5 단계, 이미지 1개 중 1개
    • Remove any adhesive residue from the battery cover and the housing cover with a scalpel / rubbing alcohol.
  6. Battery Replacement for the Kindle 4, Disconnect the battery: 6 단계, 이미지 1개 중 1개
    • Then carefully disconnect the battery flex cable, ensuring that the contacts are not being short-circuited.
  7. Battery Replacement for the Kindle 4, Remove the battery: 7 단계, 이미지 1개 중 1개
    • The battery is adhered to the housing, it takes some force to remove it. Avoid puncturing of the battery as it could catch fire and/or explode! Dispose of the old battery properly.
  8. Battery Replacement for the Kindle 4, Insert new battery: 8 단계, 이미지 1개 중 1개
    • The new battery can be fastened through the remaining adhesive residue. Reconnect the flex cable of the new battery, making sure that the contacts are not short-circuited.
  9. Battery Replacement for the Kindle 4, Control function: 9 단계, 이미지 1개 중 1개
    • The display should indicate a empty battery.
    • Before further assembly, the battery should be fully charged and it should be checked whether the device terminates the charging process when the battery is fully charged. If this is not the case, the new battery could be destroyed by the device.
    • Monitor the initial charge and carry it out in a place where there are no flammable objects.
  10. Battery Replacement for the Kindle 4, Secure the battery cover: 10 단계, 이미지 1개 중 1개
    • Secure the battery cover with the two TX 5 screws. Ensure a good fit of the back cover with a few strips of double-sided tape. Limit the amount of tape so as not to hinder future disassembly.
  11. Battery Replacement for the Kindle 4, Finish the reassembly: 11 단계, 이미지 1개 중 1개
    • The rear cover will still fit well and tight despite the four missing fastenings.
결론
다른 15명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역인들은 저희가 세상을 수리하는 데 도움을 주고 있어요! 기여하시겠습니까?
번역 시작하기 ›
작성자
2다른 기여자 명과 함께
Sigi Gruber
회원 가입일: 11/28/18
673 평판
안내서 1개를 작성함
6가이드 댓글
Es sollte m.E. noch ergänzt werden, dass der Deckel an den schmalen Seiten mit je zwei Laschen gesteckt ist. Um den Deckel zu lösen, muss man, nachdem die langen Seiten wie beschrieben geöffnet wurden, ihn etwas nach außen wölben: Man zieht dazu die schmalen Seiten in Richtung der Gehäusemitte, so dass man die Laschen herausziehen kann.
Martin Dauskardt - 답글
By far the worst part is the battery cover is welded to the back of the case with gluonium which cannot be removed with anythhng but gamma rays and kryptonite, so as the guide says,, long thin knife is what you need. The battery is glued in the same but you don’t care so much at this point :-) See step 3, the tabs top and bottom, you remove the cover by flexing it away from the frame at about the mid point.
Time and patience, gently, gently teasy monkey…
Tosspot - 답글
Just an idea for removing the well-glued-in battery - I use slivers of bamboo from the side of a largish cane, sanded to a thinnish blade. Not as strong as metal blades but non-conductive!
Patrick Quick - 답글
easiest way is to drop a few squirts of alcohol next to the battery, wait for 30 seconds to let it get behind the cell and then use a bank card or so to prize it loose, ideally a non-conductive thing. its easy as pie, the double-sided tape loosens, and the unit can just be pushed out with the card.
arjen cnx - 답글
also pre-heat the back with a hair drier to soften the double-sided tape that holds in the back cover. its a real amazon design, it doesn't like to open at all and has this nasty silicone coat on it.
arjen cnx - 답글
댓글 쓰기
조회 통계:
지난 24시간: 19
지난 7일: 116
지난 30일: 532
전체 시간: 17,804
