주요 콘텐츠로 건너뛰기
Battery Replacement for the VENSTAR Taco
필요한 것
  1. Battery Replacement for the VENSTAR Taco, VENSTAR Taco Disassembly: 1 단계, 이미지 1/3 Battery Replacement for the VENSTAR Taco, VENSTAR Taco Disassembly: 1 단계, 이미지 2/3 Battery Replacement for the VENSTAR Taco, VENSTAR Taco Disassembly: 1 단계, 이미지 3/3
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
  2. Battery Replacement for the VENSTAR Taco: 2 단계, 이미지 1/2 Battery Replacement for the VENSTAR Taco: 2 단계, 이미지 2/2
    • Repeat the previous step on the opposite side to remove the other outer casing.
  3. Battery Replacement for the VENSTAR Taco: 3 단계, 이미지 1/2 Battery Replacement for the VENSTAR Taco: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Phillips #0 Screwdriver
    $5.49
    구매
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
  4. Battery Replacement for the VENSTAR Taco: 4 단계, 이미지 1/2 Battery Replacement for the VENSTAR Taco: 4 단계, 이미지 2/2
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
  5. Battery Replacement for the VENSTAR Taco: 5 단계, 이미지 1/2 Battery Replacement for the VENSTAR Taco: 5 단계, 이미지 2/2
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
  6. Battery Replacement for the VENSTAR Taco, Battery Replacement: 6 단계, 이미지 1/1
    • A black fabric covers the ribbon retaining flap, remove it using the curved tweezers as it can be a fire hazard when soldering.
  7. Battery Replacement for the VENSTAR Taco: 7 단계, 이미지 1/1
    • Remove the battery from the side of the casing.
  8. Battery Replacement for the VENSTAR Taco: 8 단계, 이미지 1/1
    • Using a portable soldering iron, melt the solder on the red and black wires on the logic board. Be careful as you are working with the hot metal, it can burn you!
    • As an alternative to soldering, you can cut the red and black wires close to the battery and strip the ends. Then crimp the new battery's wires to the old wires on the board, making sure to match red to red and black to black.
결론
Be careful soldering the wires for the new battery onto the logic board as you can burn yourself while doing it. To reassemble your device, follow the instructions from the VENSTAR Taco Disassembly page in reverse order.
Alex Schlake
회원 가입일: 01/29/16
146 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 853
