주요 콘텐츠로 건너뛰기
Black and Decker SS12C Battery Replacement
필요한 것
  1. Black and Decker SS12C Battery Replacement, Battery: 1 단계, 이미지 1/3 Black and Decker SS12C Battery Replacement, Battery: 1 단계, 이미지 2/3 Black and Decker SS12C Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Detach the battery unit from the drill by pressing down on the battery release button and pulling the battery towards you.
  2. Black and Decker SS12C Battery Replacement: 2 단계, 이미지 1/1
    • Now that the battery component is detached, remove the 4 screws indicated [16mm].
    • Remove each screw with the T10 Torx Security Bit Screwdriver by turning counterclockwise.
  3. Black and Decker SS12C Battery Replacement: 3 단계, 이미지 1/3 Black and Decker SS12C Battery Replacement: 3 단계, 이미지 2/3 Black and Decker SS12C Battery Replacement: 3 단계, 이미지 3/3
    • Now that the screws are detached, separate the two sides of the battery.
  4. Black and Decker SS12C Battery Replacement: 4 단계, 이미지 1/2 Black and Decker SS12C Battery Replacement: 4 단계, 이미지 2/2
    • Remove the highlighted, orange component and set aside.
  5. Black and Decker SS12C Battery Replacement: 5 단계, 이미지 1/3 Black and Decker SS12C Battery Replacement: 5 단계, 이미지 2/3 Black and Decker SS12C Battery Replacement: 5 단계, 이미지 3/3
    • Grip the battery pack and detach it from the casing by pulling it upward.
    • Spring may fall out during the process.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dalton Johnson
회원 가입일: 01/31/16
337 평판
안내서 3개 작성하였습니다
University of Alabama, Team 1-8, Sydow campbell Spring 2016 University of Alabama, Team 1-8, Sydow campbell Spring 2016 회원
UA-SYDOW CAMPBELL-S16S1G8
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
I have a CD 9600 Type 3 with a B&D PS120 pack. are there any replacement packs available? Thanks!
Scott D. Deutsch - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 21
전체 시간: 840
