주요 콘텐츠로 건너뛰기
Beachwaver S-Series Clamp Spring Repair
필요한 것
    • Ensure the curling iron is turned off and unplugged.
    • Ensure the curling iron is completely cool before attempting this repair to avoid the risk of burns.
  1. Beachwaver S-Series Clamp Spring Repair: 2 단계, 이미지 3개 중 1개 Beachwaver S-Series Clamp Spring Repair: 2 단계, 이미지 3개 중 2개 Beachwaver S-Series Clamp Spring Repair: 2 단계, 이미지 3개 중 3개
    • Insert the tip of your size 000 Phillips screwdriver into the pin hole at the base of the clamp.
    • Apply pressure to the top of your screwdriver to push the pin that secures the clamp to the rod out of your curling iron.
    • Store the clamp some place you will not lose it.
  2. Beachwaver S-Series Clamp Spring Repair: 3 단계, 이미지 3개 중 1개 Beachwaver S-Series Clamp Spring Repair: 3 단계, 이미지 3개 중 2개 Beachwaver S-Series Clamp Spring Repair: 3 단계, 이미지 3개 중 3개
    • Lift the clamp off of the rod.
  3. Beachwaver S-Series Clamp Spring Repair: 4 단계, 이미지 2개 중 1개 Beachwaver S-Series Clamp Spring Repair: 4 단계, 이미지 2개 중 2개
    • Pull the spring from the base of the rod, where the clamp previously rested.
    • Install your replacement spring into the previous spring's location.
    • If your original spring is intact, it may have become misaligned. If so, reinsert the spring into the location shown in the images.
결론
첨부 문서
작성자
4다른 기여자 명과 함께
Matilyn Ballard
회원 가입일: 10/16/23
97 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 138
