주요 콘텐츠로 건너뛰기
Beaded Bracelet Clasp Replacement
필요한 것
  1. Beaded Bracelet Clasp Replacement, Beaded Bracelet Clasp: 1 단계, 이미지 1/1
    • From the left end of the bracelet, string on a crimp bead and one end of the new clasp.
    • Bring the clasp and crimp bead 3 inches from the left end of the string.
  2. Beaded Bracelet Clasp Replacement: 2 단계, 이미지 1/1
    • Loop the left end of the string through the left side of the crimp bead.
  3. Beaded Bracelet Clasp Replacement: 3 단계, 이미지 1/1
    • Push the crimp bead up close to the clasp.
    • Push the crimp bead up as close as you can to the clasp.
  4. Beaded Bracelet Clasp Replacement: 4 단계, 이미지 1/2 Beaded Bracelet Clasp Replacement: 4 단계, 이미지 2/2
    • Use the bead crimp tool to squeeze the crimp bead shut.
    • Use scissors to cut off excess string.
  5. Beaded Bracelet Clasp Replacement: 5 단계, 이미지 1/1
    • Bead the bracelet from the right end.
  6. Beaded Bracelet Clasp Replacement: 6 단계, 이미지 1/1
    • After all beads are on, string on a crimp bead and then the other end of the new clasp.
  7. Beaded Bracelet Clasp Replacement: 7 단계, 이미지 1/1
    • Loop the right end of the string through the right side of the crimp bead.
  8. Beaded Bracelet Clasp Replacement: 8 단계, 이미지 1/1
    • Pull on the string to tighten the bracelet.
    • You do not want the beads spread out.
  9. Beaded Bracelet Clasp Replacement: 9 단계, 이미지 1/2 Beaded Bracelet Clasp Replacement: 9 단계, 이미지 2/2
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kelly
회원 가입일: 03/22/16
182 평판
안내서 1개 작성함
Michigan Tech, Team 1-17, Lauer Spring 2016 Michigan Tech, Team 1-17, Lauer Spring 2016 회원
MTU-LAUER-S16S1G17
1 회원
안내서 1개 작성하였습니다
댓글 2개
Awesome!! Its very beautiful [|bracelets] each step make this bracelets so easy. Thank you!! Keep it up
daniel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 38
전체 시간: 2,398
