주요 콘텐츠로 건너뛰기
Beats Mixr Headband Replacement
필요한 것
  1. Beats Mixr Headband Replacement, Remove the caps on the headband: 1 단계, 이미지 1/1
    • Use a spudger or prying tool to remove the cap on both sides of the headband by applying pressure where the cap meets the band. Next, you will need a Phillips head #00 screwdriver to remove the screws and washer. Twist the screwdriver into the screw and pull it apart from the washer when it becomes loose.
  2. Beats Mixr Headband Replacement, Separate the ear cuff from the headband.: 2 단계, 이미지 1/1
    • Begin by pulling the two parts of the headband away from each other slowly and make sure not to break any wires. The wires will now slide free of the headband.
결론
다른 29명이 해당 안내서를 완성하였습니다.
Allie Horton
회원 가입일: 10/08/14
929 평판
안내서 1개 작성함
USF Tampa, Team 1-11, Donnelly Fall 2014 USF Tampa, Team 1-11, Donnelly Fall 2014 회원
USFT-DONNELLY-F14S1G11
1 회원
안내서 3개 작성하였습니다
댓글 3개
Started to disassemble my Mixr. After removing the covers I found the screws not so easy to remove as stated. For one, they must have used lock tite. In addition the nut and screw are so tight a screw driver will not work. Mine has spanner type nuts. I need to find a wrench that will fit.
Has anyone ran into this.
Robert Schumann - 답글
Did you figure out how to get the screws out without breaking?
simmons4jesus -
The replacement parts listed are for studio not mixr and the colors dont match!
Missy Truth - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 36
전체 시간: 14,414
