주요 콘텐츠로 건너뛰기
Beats Pill 1.0 Battery Replacement
필요한 것
  1. Beats Pill 1.0 Battery Replacement, Removing the Case Screws: 1 단계, 이미지 1/3 Beats Pill 1.0 Battery Replacement, Removing the Case Screws: 1 단계, 이미지 2/3 Beats Pill 1.0 Battery Replacement, Removing the Case Screws: 1 단계, 이미지 3/3
    • Using the spudger, create space between the speaker covers and then remove.
    • On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
    • Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
    I bought a brand new Beats Pill 1.0 online last week the first night it seemed to work all right the next day I charged it I plugged it in and it was crackling on the left hand side from the front and now the whole volume of both sides very low but it is still getting a Bluetooth connectivity I tried to reset it by holding the baby and the power button to get this thing in the back to flag it would not reset that way any suggestions I meant it is for a lot of money I paid $170 I thought I was getting a brand new device
    Steven Sudnick - 답글
  2. Beats Pill 1.0 Battery Replacement, Removing Center Cover: 2 단계, 이미지 1/3 Beats Pill 1.0 Battery Replacement, Removing Center Cover: 2 단계, 이미지 2/3 Beats Pill 1.0 Battery Replacement, Removing Center Cover: 2 단계, 이미지 3/3
    • Remove the two screws with a Phillips #0 screwdriver.
    • Slowly remove the center band and two clip rings until the adhesive separates. Sit to the side the clip rings and the center band
  3. Beats Pill 1.0 Battery Replacement, Separate the Device: 3 단계, 이미지 1/3 Beats Pill 1.0 Battery Replacement, Separate the Device: 3 단계, 이미지 2/3 Beats Pill 1.0 Battery Replacement, Separate the Device: 3 단계, 이미지 3/3
    • Use the spudger to pry the device apart along its seam, starting in the middle.
    • Open the device to separate the front and back panels.
  4. Beats Pill 1.0 Battery Replacement, Disconnect Speaker Wiring: 4 단계, 이미지 1/2 Beats Pill 1.0 Battery Replacement, Disconnect Speaker Wiring: 4 단계, 이미지 2/2
    • Carefully remove the yellow, red, black, and white wires from the motherboard.
    • Ground yourself when touching the motherboard.
  5. Beats Pill 1.0 Battery Replacement, Disconnect NFC Sensor Wiring: 5 단계, 이미지 1/2 Beats Pill 1.0 Battery Replacement, Disconnect NFC Sensor Wiring: 5 단계, 이미지 2/2
    • Carefully remove the black and red NFC sensor wires.
  6. Beats Pill 1.0 Battery Replacement, Disconnect Control Wiring: 6 단계, 이미지 1/2 Beats Pill 1.0 Battery Replacement, Disconnect Control Wiring: 6 단계, 이미지 2/2
    • Carefully remove the control cables (4 black, 1 red).
  7. Beats Pill 1.0 Battery Replacement, Battery: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Phillips #0 Screwdriver
    $5.49
    구매
  8. Beats Pill 1.0 Battery Replacement, Remove motherboard screws: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    $5.49
    구매
    • Using the same screwdriver, remove the motherboard screws along with the rubber stoppers.
  9. Beats Pill 1.0 Battery Replacement, Remove the motherboard: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Gently remove the motherboard from the case
    • Remove the yellow NFC module with Tweezers
    Is this two batteries we need to replace? Or is just the right one the battery?
    delliskd - 답글
    The batteries I bought from Amazon came with two batteries alreaded connected to one another. One one set of leads needs to be soldered
    Scott Carpenter - 답글
    Where is the yellow NFC module in the photo? I do not think there is a picture of it removed.
    salcampana - 답글
    You see a part of it on Photoshop step 7, on the top, it’s stuck behind the motherboard screws, just lift it loose with a tweezer or something, it could be a little bit ‘glued’/fixed to its surroundings. After battery change, just put it back, does not need any fixation.
    lofors -
  10. Beats Pill 1.0 Battery Replacement, Remove the power button: 10 단계, 이미지 1/1
    • Remove power button and springs.
  11. Beats Pill 1.0 Battery Replacement, Cut off battery: 11 단계, 이미지 1/1
    • Cut off the battery wires
  12. Beats Pill 1.0 Battery Replacement, Attach new battery: 12 단계, 이미지 1/1
    • Using a soldering iron attach the new battery to the motherboard with the red wire connecting to the 0.2 volts (+) and black wire connecting to the ground (-). See the soldering guide for more information on how to perform this step.
결론
다른 28명이 해당 안내서를 완성하였습니다.
Paul Haas
회원 가입일: 01/13/15
778 평판
안내서 2개 작성하였습니다
USF Tampa, Team 3-2, Hickman Winter 2015 USF Tampa, Team 3-2, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G2
4 회원들
안내서 6개 작성하였습니다
댓글 10개
donde puedo comprar la batttery para pill beats
felix - 답글
Where can you buy the replacement battery
wtmcclure - 답글
I got a replacement battery for 2.0 from Amazon, it works great! here is the link:
https://www.amazon.com/dp/B072PHZ235
And it also has battery for pill 1.0, pill XL...
Jailene -
Could you please tell what is the yellow card in the last picture?
jmestascatcoparco - 답글
Looks like the Bluetooth antenna
James Jenkins -
It is the NFC module
bobapunk -
Are there two batteries in this thing, or is the left black box a different part?
delliskd - 답글
hello, my dear friend, we have remplacement battery for Beat Pill 2.0. are you interested in introducing it? feel free to contact me.
kevin zhang - 답글
I bought a cheap speaker for no where near the price of what the pill cost me. The battery never runs out! I have had it for years! The pill on the other hand I have changed one already and does not even turn on! Beats should be ashamed for charging what they do for such a poor product with a expensive price tag! And now I’m expected to open it up myself and change the battery! I feel completely mugged off by BEATS. You know that saying about the more expensive the better the product? It’s a 100% lies! Don’t be fooled by a label! Most of the things you purchase are made in China or India and sent to another country where they are stamped and claim it’s made in that county. Wake up people !
Alex - 답글
Oh man 🙈 kann ich die auch einfach zu euch einsenden? 😂
Irina W - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 82
30일 전: 407
전체 시간: 144,959
