이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
For general disassembly guide follow this link. This guide will follow the steps taken in the general disassembly of the Beats Pill 1.0.
필요한 것
Using the spudger, create space between the speaker covers and then remove.
On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
Remove the two screws with a Phillips #0 screwdriver.
Slowly remove the center band and two clip rings until the adhesive separates. Sit to the side the clip rings and the center band
Use the spudger to pry the device apart along its seam, starting in the middle.
Open the device to separate the front and back panels.
Carefully remove the yellow, red, black, and white wires from the motherboard.
이 단계에 사용된 도구:Phillips #0 Screwdriver$5.49
Using a Phillips #0 Screwdriver, unscrew the four screws holding the bands that go over the battery.
Using the same screwdriver, remove the motherboard screws along with the rubber stoppers.
Using a soldering iron attach the new battery to the motherboard with the red wire connecting to the 0.2 volts (+) and black wire connecting to the ground (-). See the soldering guide for more information on how to perform this step.
다른 28명이 해당 안내서를 완성하였습니다.
댓글 10개
I got a replacement battery for 2.0 from Amazon, it works great! here is the link:
https://www.amazon.com/dp/B072PHZ235
And it also has battery for pill 1.0, pill XL...
Jailene -
Could you please tell what is the yellow card in the last picture?
Looks like the Bluetooth antenna
