이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using the spudger, create space between the speaker covers and then remove.
On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
Remove the two screws with a Phillips #0 screwdriver.
Slowly remove the center band and two clip rings until the adhesive separates. Sit to the side the clip rings and the center band
Use the spudger to pry the device apart along its seam, starting in the middle.
Open the device to separate the front and back panels.
Carefully remove the yellow, red, black, and white wires from the motherboard.
Using the Phillips #0 screwdriver, unscrew the two screws that holds the speakers down.
Each speaker is held down by two clips. On the front face of the speaker, push the speaker outward while pushing one of the clips that holds it down to the side. Repeat this on the other speaker and clip. The speakers should pop out.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 10개
Do you have a link to the speakers that are used for the speaker pill, the current one seems to be broken and I cant find the replacements anywhere
Just wanted to add a comment regarding where to find the actual replacement speakers for the Beats Pill 1.0. I quite certain that the over all size of each individual speaker is 1" including the plastic bezel around the speaker. The actual size of the speaker itself is 3/4" and I believe I have found a replacement speaker to use if one of the speakers in your Beats Pill 1.0 gets blown or damaged. Below is the link to the replacement speaker, found on www.partsexpress.com. It looks almost identical to the stock speaker installed in the Pill 1.0, minus the custom bezel around the speaker that is used to secure the speakers inside the Pill.
http://www.parts-express.com/tymphany-pm...
Buying all 4 speakers at once saves you 75 cent compared to the price of buying just a single speaker.
Hope this helps anyone looking for replacement speakers for their Beats Pill 1.0
I just got all 4 new speakers to replace the older ones as the rubber rims have all soften and sort of disintegrated/damaged. Only problems with the replacement speakers plastic body are not same as original ones. So the speakers won’t fit the 2 clips, so almost no way to secure the speakers. Probably need to be Super glue.
Victor -
I plugged my speaker in because it needed a charge and the metal piece inside the speaker went into it help
