주요 콘텐츠로 건너뛰기
Beats Pill XL Motherboard Replacement
필요한 것
  1. Beats Pill XL Motherboard Replacement, Case: 1 단계, 이미지 1/2 Beats Pill XL Motherboard Replacement, Case: 1 단계, 이미지 2/2
    • Using a plastic opening tool, pry the casing from the rest of the device.
    • Pry all the way around the edge and then pull apart.
    • It should be relatively easy, to pull apart. Don't be afraid to apply a necessary force.
  2. Beats Pill XL Motherboard Replacement: 2 단계, 이미지 1/1
    • Using your thumb, remove the 8 rubber plugs in order to get to the screws.
    • Simply rub them towards the speakers and they will slide out enough to grip the edge and pull them out.
    • In the picture provided, we labeled four of them on one side of the Beats Pill XL. The other four are symmetrical to these four on the other side of the device.
  3. Beats Pill XL Motherboard Replacement: 3 단계, 이미지 1/2 Beats Pill XL Motherboard Replacement: 3 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, remove the 8 (10mm maxi-loc Phillips #2) screws that hold the casing together.
  4. Beats Pill XL Motherboard Replacement: 4 단계, 이미지 1/2 Beats Pill XL Motherboard Replacement: 4 단계, 이미지 2/2
    • Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
    • Separate at a slow constant force to avoid damage to the ribbon cables.
  5. Beats Pill XL Motherboard Replacement: 5 단계, 이미지 1/2 Beats Pill XL Motherboard Replacement: 5 단계, 이미지 2/2
    • Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
    • Never pull the cables by the cord, as this could cause damage to the cables and/or motherboard. Always disconnect the cables from the base by the motherboard.
  6. Beats Pill XL Motherboard Replacement: 6 단계, 이미지 1/2 Beats Pill XL Motherboard Replacement: 6 단계, 이미지 2/2
    • Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
    • Even though there are two batteries, there is only one cable connecting the two to the motherboard.
  7. Beats Pill XL Motherboard Replacement, Motherboard: 7 단계, 이미지 1/1
    • After completing the guide for removing the case, remove the cables connecting the speakers.
    • Simply pull up on them without pulling on the wires themselves.
  8. Beats Pill XL Motherboard Replacement: 8 단계, 이미지 1/1
    • Set the half of the device containing speakers to the side.
  9. Beats Pill XL Motherboard Replacement: 9 단계, 이미지 1/2 Beats Pill XL Motherboard Replacement: 9 단계, 이미지 2/2
    • Remove all five remaining connectors on the motherboard.
    • Do not remove the Bluetooth antenna in the bottom right corner of the motherboard.
  10. Beats Pill XL Motherboard Replacement: 10 단계, 이미지 1/2 Beats Pill XL Motherboard Replacement: 10 단계, 이미지 2/2
    • Remove the chip for the Bluetooth antenna located to the top right of the motherboard.
    • The other end of this chip is connected to the motherboard via the Bluetooth antenna. Be careful not to tug on that end for any reason.
  11. Beats Pill XL Motherboard Replacement: 11 단계, 이미지 1/2 Beats Pill XL Motherboard Replacement: 11 단계, 이미지 2/2
    • Using a Phillips #2 screwdriver, unscrew the 4 (8mm pan head Phillips #2) screws holding the motherboard onto the case. They are located in the four corners of the board.
  12. Beats Pill XL Motherboard Replacement: 12 단계, 이미지 1/2 Beats Pill XL Motherboard Replacement: 12 단계, 이미지 2/2
    • Using both hands, gently lift the motherboard from the case.
    • You have successfully removed the motherboard.
    • Be sure to put the board somewhere it will be safe when it is not being worked on.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Michael
회원 가입일: 03/11/15
659 평판
안내서 2개 작성하였습니다
Colorado Springs, Team 9-2, Panko Spring 2015 Colorado Springs, Team 9-2, Panko Spring 2015 회원
UCCS-PANKO-S15S9G2
3 회원들
안내서 7개 작성하였습니다
댓글 5개
Disculpe la molestia quisiera saber el número de parte de los transistores Q2,Q3
Armando Artega - 답글
I have a question regarding the contents of circuit.
which type of IC is used in the circuit which is hided by a marker. And if you have that ic than how can i contact you.
Ravi Makwana - 답글
I need the Beats Pill XL Motherboard.. where i can buy
Petrus Damianus G - 답글
Bonjour impeccable bien expliqué
Ou puis-je trouvé cette carte
Merci beaucoup
Gilbert Rodrigues - 답글
0967197831 este es mi movil nesecito saber cuanto cuesta la placa de este beatspill xf ayudeme
Stalin Salavarrialoor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 39
전체 시간: 10,763
