주요 콘텐츠로 건너뛰기
Beats Solo 2 Wire Replacement
필요한 것
  1. Beats Solo 2 Wire Replacement, Core Wire: 1 단계, 이미지 1/1
    • Pull out the wire from the beats. The wire is a jack wire and requires nothing special to remove.
  2. Beats Solo 2 Wire Replacement: 2 단계, 이미지 1/2 Beats Solo 2 Wire Replacement: 2 단계, 이미지 2/2
    • Remove the ear cushions from the headset. The preferred method to do this is to use a screwdriver and pry the cushions off.
  3. Beats Solo 2 Wire Replacement: 3 단계, 이미지 1/3 Beats Solo 2 Wire Replacement: 3 단계, 이미지 2/3 Beats Solo 2 Wire Replacement: 3 단계, 이미지 3/3
    • Remove the second cushion until both cushions are removed.
  4. Beats Solo 2 Wire Replacement: 4 단계, 이미지 1/3 Beats Solo 2 Wire Replacement: 4 단계, 이미지 2/3 Beats Solo 2 Wire Replacement: 4 단계, 이미지 3/3
    • Remove the screws from both ear bases.
  5. Beats Solo 2 Wire Replacement: 5 단계, 이미지 1/2 Beats Solo 2 Wire Replacement: 5 단계, 이미지 2/2
    • Once the screws are removed, pop off the inner speakers. Do this for both sides
  6. Beats Solo 2 Wire Replacement: 6 단계, 이미지 1/3 Beats Solo 2 Wire Replacement: 6 단계, 이미지 2/3 Beats Solo 2 Wire Replacement: 6 단계, 이미지 3/3
    • After you have removed the second internal speaker, you can begin the process of removing the wire. BE CAREFUL with this step, make sure you don't pull off the circuit board.
  7. Beats Solo 2 Wire Replacement: 7 단계, 이미지 1/3 Beats Solo 2 Wire Replacement: 7 단계, 이미지 2/3 Beats Solo 2 Wire Replacement: 7 단계, 이미지 3/3
    • Now we are going to remove the circuit board holder. Take off the white cover to get access to the screw. Then remove the screw and circuit board holder.
  8. Beats Solo 2 Wire Replacement: 8 단계, 이미지 1/3 Beats Solo 2 Wire Replacement: 8 단계, 이미지 2/3 Beats Solo 2 Wire Replacement: 8 단계, 이미지 3/3
    • slowly pry away cover
결론
다른 8명이 해당 안내서를 완성하였습니다.
Darien Jewel
회원 가입일: 11/28/16
221 평판
안내서 1개 작성함
Coast Union High School, Team 1-4, Hartzell Fall 2016 Coast Union High School, Team 1-4, Hartzell Fall 2016 회원
CUHS-HARTZELL-F16S1G4
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 37
전체 시간: 5,730
