주요 콘텐츠로 건너뛰기
Beats Solo 2 Wireless Earpads Replacement
필요한 것
  1. Beats Solo 2 Wireless Earpads Replacement, Earpads: 1 단계, 이미지 1/3 Beats Solo 2 Wireless Earpads Replacement, Earpads: 1 단계, 이미지 2/3 Beats Solo 2 Wireless Earpads Replacement, Earpads: 1 단계, 이미지 3/3
    • Set the headphones down on a flat surface.
    • Insert a plastic card or opening pick between between the earpads and the speaker housing.
    • Carefully pry around the entire perimeter of the the pads until they fully release.
  2. Beats Solo 2 Wireless Earpads Replacement: 2 단계, 이미지 1/1
    • Use the card to clean up the adhesive residue left on the headphones.
    • Apply high-concentration isopropyl alcohol to a cloth and use it to remove any lingering adhesive.
  3. Beats Solo 2 Wireless Earpads Replacement: 3 단계, 이미지 1/1
    • Fold the other side of the headphones you are not working on.
    • This makes it easier to work and focus on the side you are on.
    • Carefully pick up the new pads and line them up with the Beats.
    • The new earpads come with the adhesive on them already; you just have to peel the plastic covering off.
  4. Beats Solo 2 Wireless Earpads Replacement: 4 단계, 이미지 1/1
    • Press down on the new pad to make sure it adheres to the headphones.
    • Make sure to go around the pad and press down on every part.
  5. Beats Solo 2 Wireless Earpads Replacement: 5 단계, 이미지 1/1
    • Find a large object and place the headphones on it just like the object is wearing the headphones.
    • Leave the headphones on the object for an hour so it can clamp the earpads to itself.
    • After 1 hour, you are good to go.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Ayotunde Dada
회원 가입일: 01/11/24
151 평판
안내서 1개 작성함
York University, Team 1-10, O'Regan Summer 2024 York University, Team 1-10, O'Regan Summer 2024 회원
YORK-O'REGAN-SU24S1G10
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 40
전체 시간: 135
