주요 콘텐츠로 건너뛰기
Beats Solo 3 Earpads Replacement
필요한 것
  1. Beats Solo 3 Earpads Replacement, Earpads: 1 단계, 이미지 1/2 Beats Solo 3 Earpads Replacement, Earpads: 1 단계, 이미지 2/2
    • Use a halberd spudger to create a gap between the earpads and the main body.
  2. Beats Solo 3 Earpads Replacement: 2 단계, 이미지 1/2 Beats Solo 3 Earpads Replacement: 2 단계, 이미지 2/2
    • Peel away the earpads from the headphone earcups.
    • Be gentle when separating the earpads from the main body. Too much force may damage the main body.
  3. Beats Solo 3 Earpads Replacement: 3 단계, 이미지 1/3 Beats Solo 3 Earpads Replacement: 3 단계, 이미지 2/3 Beats Solo 3 Earpads Replacement: 3 단계, 이미지 3/3
    • Remove the black tape with your hands.
    • Be sure to clean the black tape thoroughly, as uncleaned tape can hinder the adhesive of the new pads.
  4. Beats Solo 3 Earpads Replacement: 4 단계, 이미지 1/1
    • Spread a thin layer of glue around the grey perimeter of the new earpads.
    • Don’t put too much glue on or it will spill out and make the earpads dirty.
  5. Beats Solo 3 Earpads Replacement: 5 단계, 이미지 1/2 Beats Solo 3 Earpads Replacement: 5 단계, 이미지 2/2
    • Install the new pads.
    • Be sure to position the earpads properly on the earcups before adhering.
    • The pads may take a minute to stay together, be patient.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Xin
회원 가입일: 09/19/21
315 평판
안내서 1개 작성함
York University, Team F-28, Woodhouse Fall 2021 York University, Team F-28, Woodhouse Fall 2021 회원
YORK-WOODHOUSE-F21SFG28
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 104
30일 전: 467
전체 시간: 14,006
