주요 콘텐츠로 건너뛰기
Beats Solo 3 Headband Replacement
필요한 것
  1. Beats Solo 3 Headband Replacement, Headband: 1 단계, 이미지 1/3 Beats Solo 3 Headband Replacement, Headband: 1 단계, 이미지 2/3 Beats Solo 3 Headband Replacement, Headband: 1 단계, 이미지 3/3
    • Carefully partially remove the headband cushion cover. Be careful not to rip the two headband eyelets just above the screws on each end of the headband.
  2. Beats Solo 3 Headband Replacement: 2 단계, 이미지 1/2 Beats Solo 3 Headband Replacement: 2 단계, 이미지 2/2
    • With the main part of the cover off, pull the head band cover up and out of the metal headband ends, exposing the screws underneath.
  3. Beats Solo 3 Headband Replacement: 3 단계, 이미지 1/3 Beats Solo 3 Headband Replacement: 3 단계, 이미지 2/3 Beats Solo 3 Headband Replacement: 3 단계, 이미지 3/3
    • Unscrew all four 1.4 mm screws on the right and left ends on the underside of the headband using a T5 Torx screwdriver.
  4. Beats Solo 3 Headband Replacement: 4 단계, 이미지 1/1
    • Pull the metal headband end out from the headband slightly, and disconnect the rubber band from the hook.
  5. Beats Solo 3 Headband Replacement: 5 단계, 이미지 1/2 Beats Solo 3 Headband Replacement: 5 단계, 이미지 2/2
    • Remove the inner headband by gently prying the edges and corners.
  6. Beats Solo 3 Headband Replacement: 6 단계, 이미지 1/1
    • Carefully peel up the glued wire in the headband.
  7. Beats Solo 3 Headband Replacement: 7 단계, 이미지 1/1
    • Pull the headband out of the slots gently.
  8. Beats Solo 3 Headband Replacement: 8 단계, 이미지 1/1
    • Put the new headband into the slots carefully.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Joseph Konadu
회원 가입일: 03/24/21
211 평판
안내서 1개 작성함
UMass Dartmouth, Team S1-G13, Riel Spring 2021 UMass Dartmouth, Team S1-G13, Riel Spring 2021 회원
UMASSD-RIEL-S21S1G13
1 회원
안내서 2개 작성하였습니다
댓글 2개
help when i was putting on the new headband the snap on middle parts fell out and i cant put them back in (the metal connection parts)
koro - 답글
same it happen to me as well
Bardo -
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 58
30일 전: 200
전체 시간: 11,385
