주요 콘텐츠로 건너뛰기
Beats Solo Pro Side panel Replacement
필요한 것
  1. Beats Solo Pro Side panel Replacement, Extending the Headphones: 1 단계, 이미지 1/2 Beats Solo Pro Side panel Replacement, Extending the Headphones: 1 단계, 이미지 2/2
    • Slide the headphones down to extend the hinge.
  2. Beats Solo Pro Side panel Replacement, Prying off the side panel: 2 단계, 이미지 1/2 Beats Solo Pro Side panel Replacement, Prying off the side panel: 2 단계, 이미지 2/2
    • Once extended insert a prying the new gap to unclip the panel
    • Once unclipped repeat on the other side of the panel
    • The two clips are towards the top of the panel, as indicated by the location of the metal prying tool in the image.
  3. Beats Solo Pro Side panel Replacement, Sliding out the side panel: 3 단계, 이미지 1/2 Beats Solo Pro Side panel Replacement, Sliding out the side panel: 3 단계, 이미지 2/2
    • Slide the panel down and lift away from the headphone just until its separated
    • Don't pull the plastic piece offs there is still cables attached to it
  4. Beats Solo Pro Side panel Replacement, Tightening or replacing: 4 단계, 이미지 1/2 Beats Solo Pro Side panel Replacement, Tightening or replacing: 4 단계, 이미지 2/2
    • If needed tighten the PH00 screw(if your side panel has came loose on it own you will need to do this to fix the issue)
    • If you want to replace the side panel you will need to carefully pry the cables out from where they are glued in and glue them in to the new panel(refer to second image)
결론
To reassemble complete steps in reverse:-)
다른 4명이 해당 안내서를 완성하였습니다.
HelloMacOS
회원 가입일: 01/24/22
26,143 평판
안내서 11개 작성하였습니다
Repair is War on Entropy Repair is War on Entropy 회원
Community
27 회원들
안내서 1,209개 작성하였습니다
댓글 한 개
Muchas gracias por tus pasos a seguir.
Yo tengo un problema pero con el tornillo que esta tapado por los cables, al cual no puedo acceder para poderlo apretar contra la tapa exterior.
Alfredo Olvera - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 21
30일 전: 104
전체 시간: 3,221
